This is an approch to provide a generic build for rk3026boards with Atheros AR9271 wifi.
Build is done for Cube U25GT2-H and comes with loader RK3028A
– stock 4.2.41 recovery, CWM 6.0.3.1 recovery
– system ext4
– kernel #93 preempt 05.12.2013
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Instructions are included in the download pack.
hints:
– higher performance > disable animation scales in developer options
– don't show su notifications > disable in Superuser
- to prettify the build use Xposed Framework > Starter Pack
VohukainPer aspera ad astra, we rock the Tablets !
For testing pls find below the following kernel (change in folder rockdev/Images before flash):
For the following tabs you need to change the Loader, too: http://crewrktablets.arctablet.com/?wpfb_dl=1868
GenX GX250 - http://crewrktablets.arctablet.com/?wpfb_dl=1847
JEKA JK702 - http://crewrktablets.arctablet.com/?wpfb_dl=2062
MyPhone MyTab 7+ - http://crewrktablets.arctablet.com/?wpfb_dl=2261
Q8 - http://crewrktablets.arctablet.com/?wpfb_dl=2061
Before flash anything into the tab pls make sure you have the genuine firmware as a fall-back position.
2014/08/21
Is there any change to get KitKat update for devices which work with this rom? My kernel (Linux version 3.0.36+ (lijian@ibm-0A) (gcc version 4.6.x-google 20120106 (prerelease) (GCC)) #69 SMP PREEEMPT Thu Jan 16 15:50:05 HKT 2014) doesn't have selinux support so it might be a problem(?).
However, I'm happy with this anyway. What kind of magic did you use with this rom?!? AnTuTu gives me over (non-verified) 12k score. It is fantastic even so AnTuTu is not the best way to measure performance. Also it is funny that device "is" now Nexus 7. Great and fast rom!
KitKat will only boot on a selinux kernel. Anyway, you should be fine with the JB build. Device is spoofed as Nexus7, so one have a wider Play Store range.
Negative, I do not have kernel sources nor a kernel defconfig for the tab.
50 Guest(s)
Devices in use: Desktop (42), Phone (8)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
