Gents,
KitKat has landed on Chuwi V17pro (from SN 1140300001 onwards)
This is a build for Cube U25GT2-T which runs also on the Chuwi V17pro.
– system ext4
– selinux kernel ruan #336
– internal storage 2,0 GB
– device spoofed as Nexus 7
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
hints:
- to improve UI feeling disable all animation scales in developer options
– load kernel modules > enable init.d ON in Pimp my Rom (reboot)
– to disable su notifications change notification in su app
This is a gen2 loader firmware.
– Oma -
grobsen, loulou1212Per aspera ad astra, we rock the Tablets !
2014/05/07
Hi, yesterday i put this firmware to chuwi v17 pro and after i have something like on the pictures below. I cant fix it. Help me plz.
P.s. Later I put this rom, but nothing has changed. And I tried to find stock firmware, but I could not.
Looks like this is the old V17 pro. What is the S/N?
Most likely the old model. Kernel is here: http://crewrktablets.arctablet.com/?wpfb_dl=1703
Try the JB build using that kernel.
grobsenPer aspera ad astra, we rock the Tablets !
Pls upload a dmesg log?
Boot tab fresh, try a few times wifi on/off, open a terminal and type:
su
dmesg >/mnt/sdcard/dmesg.txt
- Oma -
2014/05/23
First of all: Thank you very very much for your Roms.
It's very fast and smooth
But unfortunally Wifi didn't work on my device.
I'm on your JellyBean ROM with the Kernel linked above, just like Alcatraz.
KK ROM gives me the same screen like Alcatraz. 1stGen Device too.
Here's my dmesg from the wifi problem on JB:
Thanks in advance!?
Ok, MT7601 wifi ... can't work.
Pls try this fix (install via CWM): http://crewrktablets.arctablet.com/?wpfb_dl=1762
Fine.
A factory reset should not be necessary.
For KK we need a kernel with selinux on. Maybe someone could provide the kernel sources?
2014/07/05
Off-topic, but.. Oma7144, what would it take to port this Android 4.4.2 kernel/rom to a similar tablet, the Lenco TAB-705: http://www.lenco.com/nl/p/tab-705-2/
I'm reasonably proficient with ADB if you need any data from the tablet. Feel free to contact me however you like.
btw, what about F2FS for the /data partition? It works great on Moto G.
101 Guest(s)
Devices in use: Desktop (84), Phone (15), Tablet (2)
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
pablovs
