[ ROM ] Advan T2E Android 4.4.2 KitKat custom root firmware (2015/01/30)
Build is for ESP8089 wifi. KK needs a selinux kernel!
2015/01/30 - 20:37
Gents,
this is a KitKat build for Advan T2E. Build is for ESP8089 wifi ;-)
Oma T2E build v1.0a
– system ext4
– internal storage 2 GB and swapped mounts
– selinux kernel #121 preempt 3. Jul 2014
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
hints:
use Nova launcher and set animation/scroll to “faster than light” and
enable Entropy Fixer with value 256
 – Oma -
V17HD_20c.pngImage Enlarger
 v1.0_01.pngImage Enlarger
 v1.0_03.pngImage Enlarger
 v1.0_02.pngImage Enlarger
2015/01/31 - 13:10
http://advandigital.com/catalog/product/view/id/advan+Tablet+T2E
The tab has only 4 GB NAND.
Update post #1 with build v1.0a: internal storage 2 GB and swapped mounts (up to 32GB for game data).
v1.0_swapped-mounts.pngImage Enlarger
s1der
2015/04/12 - 21:05
Hi, thank you for this release !
Just one thing : I don't understant the instruction :
"3) flash the CWM recovery with AndroidTool
     a) go to app drawer, open RebootMenue and Reboot to Bootloader"
My tab doesn't boot, it stays freezed at the first screen "android"..
Can somebody heps me ?
Thanks in advance !
68 Guest(s)
Devices in use: Desktop (60), Phone (8)
cutierogue
hans41
