2015/07/09
Hello ,I need Firmware plz for : Â Â (Eddy Paddy Kids Tab - Nano TAB)
rockchip rk3026 Â
device KT730 rks753
os 4.4.2 (KOT 49H)
build eng-izw-20140505-172159
kernel 3.0.36+
numéro du build MQNKT102014
Android: 4.4.2; eng-izw-20140505-172159- SDK19
http://s1045.photobucket.com/user/jimi113/media/01_zpsxoerjtna.jpg.html
General Specifications
Manufacturer: rockchip
Model: KT730
Android: 4.4.2; eng.izw.20140505.172159; SDK19
Display: 800 x 480; DPI: 120; Evaluated Size: 7,8"
Touch Screen: Multitouch 5 points
GPU: Mali-400 MP; ARM; OpenGL ES-CM 1.1; OpenGL ES 2.0
RAM: 421 MB
Flash: 2.000 GB
Processor: 2 cores; ARMv7 Processor rev 1 (v7l) rk3026; Max: 1008,0 MHz; Min: 312,0 MHz
Communications
Phone: None
WiFi: wlan
USB Host: Yes
Bluetooth: No
What has happen with the stock firmware?
2015/07/09
thank you for the reply and for what you do ;
i need this Firmware because the original one is out of order;
in the first time the problem is the gapps applications not working ,after numerous unsuccessful manipulation now it's a black screen from the boot after the logo :'( Are there a solution?
rockchip rk3026
M775_V1.41_1
2014-07-10
Try to dump the firmware. See other thread in this forum.
2015/07/09
good morning;
this is the firmware dump http://www.mediafire.com/download/sxu08ab897re426/rockchip_rk3026_M775+.rar
and with droid explorer-dalvik debug monitor i saved this file debug http://www.mediafire.com/download/au3r8bfevukb47d/log-debug.txtÂ
Thank you for your patience
Dump looks good. Can I have also a dmesg log?
Ok, ESP8089 wifi.
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=2694
Just change kernel in folder rockdev/Image before flash.
Ok, I shall do a specific build. Will take a few days.
jimi13Per aspera ad astra, we rock the Tablets !
The dumped system is full of xposed modules and other strange stuff. Tried for a while but unfortunately I cannot make this work. I guess it is somehow deep corrupted. Sorry.
62 Guest(s)
Devices in use: Desktop (56), Phone (6)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
