2015/02/06
Hi! , i Have Blow Blacktab 10 tablet , this tablet has rockchip 3026 , and i'm thinking about android kitkat , its possible to run kitkat on this tablet ?
Official Firmware : http://www.blow.com.pl/download/Firmware_BlackTAB10_II.rar
Ok, here is the kernel: http://crewrktablets.arctablet.com/?wpfb_dl=2438
You can try this build: http://www.arctablet.com/blog/forum/crewrktablets-rk3026-entwicklung-und-customroms-development-and-croms/rom-roverpad-trc7-android-4-2-2-jelly-bean-custom-root-firmware-20140421/
KK is not possible because you will need a selinux kernel.
miXXed404Per aspera ad astra, we rock the Tablets !
2015/02/06
Thanks for reply , can you give me instructions how to flash it , i don't know what rom download , can you give direct link to this rom that may run on my tablet ?, if you won't give instructions can you give pre-configured rk batch tool (maybe this program) to flash rom to my device? Sorry if you don't understand because im from Poland
Well, the build in post #1: http://crewrktablets.arctablet.com/?wpfb_dl=1696
Just change your kernel in folder rockdev/Images before flash. Instructions are included in the download pack.
Yes.
2015/02/06
Thanks for rom , working good but found bug, while pressing vol+ volume going down and while pressing vol - volume going up , im thinking , how to enable or include selinux on my kernel so i can boot kitkat....
I found something interesing , Maybe this is source for RK3026 kernel
2015/05/05
hello i can install kitkat in my tablet?
mode rk3016
manufactured rockchip
board rk30sdk
bootloader unknow
build id rk3016-eng 4.2.2 JDQ39 eng.qiaohy.201400628.185448 release-keys
hardware rk30board
android version 4.2.2
API leve 17
Java VM Dalvik 1.6.0
Open GL ES version 2.0
kernel architecture armv7l
kernel version 3.0.36+(eng.qiaohy.201400628.185448)
screen size 7.98 inches
screen resolution 1024x768
screen density 145 dpi
total ram 1024 MB
aviable ram 599 MB (58%)
internal storage 0,98 GB
aviable storage 0,20GB (20%)
nand flash 5,55 GB
root access yes
cores 2
architecture 2x ARM Cortex-A9 @ 1.01 GHz
revision r4p1
process 40nm
clock speed 31MHz - 1.01 Ghz
GPU vendor ARM
GPU renderer Mali-400 MP
Never seen a rk3016 tab. Most likely a rk3026. Pls check with this app: https://play.google.com/store/apps/details?id=com.arctablet.cpucheck
cutter23Per aspera ad astra, we rock the Tablets !
2015/05/05
oh yes, my mistake. this is the real information
which it is better for my case
model rk3026
board rk30sdk
bootloader unknow
hardware rk30board
API leve 17
total ram 1024 MB
nand flash 5,55 GB
root access yes
cores 2
revision r4p1
process 40nm
GPU vendor ARM
Ok, only this JB firmware/kernel available?
Ok, upload boot.img, kernel.img and a dmesg log.
2015/05/05
hello here are the kernel and boot 😀
http://www.mediafire.com/download/n9zrqletghclny1/rk3026kernelboot.zip
where are found dmesg log ?
Use tools like this: http://forum.xda-developers.com/showthread.php?t=1944776
Currently Online: VMILCINOV
69 Guest(s)
Devices in use: Desktop (66), Phone (4)
VMILCINOV
