2014/11/22
Welcome. I have a MyTab 7+ tablet. It is running Android 4.2.2 Jelly Bean.Â
Is it possible to upgrade to 4.4 KitKat ?
I have a full system dump and system logs (logcat + DMESG)Dump (Created with rkDumper): https://dl.dropboxusercontent.com/u/47393244/dump.zip
Logs: https://dl.dropboxusercontent.com/u/47393244/logs.zip
Thank you in advance for your answer and ask for your help!![]()
I'm sorry for any errors caused by poor knowledge of English. I am of Polish.![]()
Negative. For KitKat you will need a selinux kernel. I guess kernel sources are not published?
Just for documentation purpose: MyTab 7+ has Atheros AR9271 wifi.
microa, koreaderPer aspera ad astra, we rock the Tablets !
There is not much development for rk3026boards.
A build for Atheros wifi is here: http://www.arctablet.com/blog/forum/crewrktablets-rk3026-entwicklung-und-customroms-development-and-croms/rom-cube-u25gt2-h-android-4-2-2-custom-root-firmware-20140622/
No need to flash the loader. Just change the kernel in folder rockdev/Images: http://crewrktablets.arctablet.com/?wpfb_dl=2261
Fine.
75 Guest(s)
Devices in use: Desktop (69), Phone (6)
