Need Rom Tablet MasterByco BY-7DC RK3026
ESPECIFICATION MasterBico Tablet Dual Core CPU Rockchip 3026 Cortex A9, 1,5GHz*2, Mali 400 Android 4.2 Jelly Bean, 1.0 GHZ, Dual Camera G-sensor 512MB Ram, 4GB
cesaraltuve
Forum Posts: 12
2016/05/01 - 18:57
In the board information.
Need ROM tablet Master Bico KR706F V1.0 2014.01.24
KR3026
GSL1680
RTL8188ETV
DUAL CAM
2016/05/01 - 19:20
What has happen with the genuine firmware? Any backup?
cesaraltuve
Forum Posts: 12
2016/05/01 - 19:29
No, tablet bricked.
cesaraltuve
Forum Posts: 12
2016/05/01 - 19:36
rom works with some , but not rotate the screen, the camera does not work and does not work the wifi
2016/05/01 - 19:37
Every tab has its specific kernel (hardware abstraction layer). Without the genuine kernel no change to proceed.
Ask the re-seller for a download link or try to find somebody else with this tab who can dump the firmware.
cesaraltuve
Forum Posts: 12
2016/05/01 - 19:45
Is that that's the problem , I have not found anyone that has that tablet. It does not have official support
2016/05/01 - 19:50
Which Rom? Is touch working?
cesaraltuve
Forum Posts: 12
2016/05/01 - 19:59
With this rom works: Rom the screen is used , but does not rotate .
2016/05/01 - 20:09
Ok, I will have a look and come back to you tomorrow.
2016/05/01 - 21:13
Simple JB build:
ro.build.display.id=MID.20131211.162139
ro.build.version.incremental=eng.crownh807.20131211.161436
ro.product.model=MID
ro.product.brand=MID
Here is the kernel: http://crewrktablets.arctablet.com/?wpfb_dl=2870
Build: http://www.arctablet.com/blog/forum/crewrktablets-rk3026-entwicklung-und-customroms-development-and-croms/rom-roverpad-trc7-android-4-2-2-jelly-bean-custom-root-firmware-20140421/?lang=fr
Just change the kernel in folder rockdev/Image before flash.
cesaraltuve
Forum Posts: 12
2016/05/02 - 13:10
Even still does not rotate the screen , although it seems lighter . The wifi does not work .
cesaraltuve
Forum Posts: 12
2016/05/02 - 21:00
I do not understand how to place the package Oma_TRC7_JB_v1.0_Modell_fix_Onn_07D
cesaraltuve
Forum Posts: 12
2016/05/02 - 21:02
I would not mind the touch turn , because everything else works. I am interested wifi that does not work.
2016/05/02 - 21:19
Touch could be corrected later. First thing is to find the right build for wifi. So try the other builds.
77 Guest(s)
Devices in use: Desktop (71), Phone (6)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
