2014/01/07
Hi all,
first, many thanks to CrewRKtablets and Oma for the CM10.1 for the RK2918.
I just updated my Odys One successfully with the Latest CM10.1 build
To bring your Odys One to flash mode you need to Press and Hold the Reset button in the small hole.
Connect your Odys One to USB while still holding the Reset button pressed, until Windows ask for Driver Installation or RKAndroidTool detects your device.
- The Odys One Kernel is available in the kernel archive.
- After flashing the ROM Format NANDhas been applied from the MicroSD card. I had to install the TabletUI fix since the PhabletUI goes out of the screen in landscape mode.
- Also mandatory is the Sensor Fix and the Screen rotation fix.
- As Touch Recovery i flashed an older version since it is easier to handle on the Odys One.
Thats it.
Enjoy your Odys One with CM10.1 Android 4.2.2.
Regards, N23 LZ
Just tested with Antutu 4.1.6: 4220 points
1 small issue: Camera 180° reversed.
Thank you for feedback!
The Odys One was not very popular. So more then happy that we could up-value this tab, too
Rock293031Per aspera ad astra, we rock the Tablets !
2014/01/07
Fixed the camera 180° rotation issue with the Camera Rotation Fix.
Thanks again!!
78 Guest(s)
Devices in use: Desktop (71), Phone (7)
hans41
rickybk
soniya07
ironmangitar
