2013/07/24
Hi !!!
I have a Memup Slidepad 708NG with firmware 1.0.9.1.
I'd like to upgrade it to JB.
In order to do that, I downloaded :
-Â CrewRKTablets_RK29_Loox_AOSP_4.2.2_v1.4_20130721.7z
-Â kernel_308_ng708_slidepad.7z
-Â Oma_JB_v1.2_Modell_fix_Neo X7.zip
-Â CrewRKTablets_AOSP_4.2.2_Format_NAND_Fix.zip
I used RKAndroitTool v1.29, checked Loader, set the kernel on my SP708NG stock "kernel.img" file extracted from "kernel_308_ng708_slidepad.7z", erased IDB and ran.
Then it reboots but get stuck at boot on the "crew rktablets" logo...
Some help, please ?
Thanks a lot...
Do not use model fixes that are for other builds!
Try again without the model fix.
- Oma-
md83200Per aspera ad astra, we rock the Tablets !
2013/07/24
It worked... Great !
I'm gonna translate my notes to english and publish them here, probably tomorrow...
Still one question, though...
Full screen is enabled, but even when it's not, I can't see any item within the system bar (battery status, etc.)
Also, the tablet screen does not rotate anymore.
Camera picture is mirrored.
Thanks a lot for your great work !
53 Guest(s)
Devices in use: Desktop (50), Phone (3)
VMILCINOV
