2014/01/23
just looking for an xpress pro homebrew kernel. I just recognized the homebrew kernel for the xpress(non-pro), but not for the pro. Or can I use the non-pro kernel for the pro tablet?
Do I need anything else to flash the newest CM10.1 to the xpress-pro? I currently run the Oma JB 1.2.3a and as far as I remember I needed to apply some fixes.
Thanks for your help.
killah78
And by the way: Does anybody have the stock-rom for the xpress-pro? It is not available on the odys-page.
look about our site:
http://crewrktablets.arctablet.com/ and you will find all.
You need for CM-10.1:
Image, the newest: http://crewrktablets.arctablet.com/?p=1873
replace in folder rockdev/Image the kernel.img with your stock: http://crewrktablets.arctablet.com/?wpfb_dl=370
good luck
netlars
2014/01/23
Thanks netlars,
that website is where I come from before posting here.
And I found the post of Jochenkauz about the homebrew-kernel from 31.12.13.
There isn't a kernel for the xpress pro, only the xpress (non-pro).
Is it possible to add the kernel for the xpress pro?
And after flashing CM10.1 I do not need any model-fix-patch? After flashing the Oma 1.2.3a release I needed to patch because of having trouble with the screen rotation. Or is that resolved inside this rom?
Thanks for your answers.
killah78
At the moment not exist an homebrew-kernel.
Please flash the build as is, only change the kernel to your stock-kernel.
Then test the postet sensor fixes for rotation.
A model-fix dos'nt exist.
netlars
2014/01/23
will nochmal was anhängen. Hoffe deutsch ist ok.
Ich weiss nicht, ob JochenKauz hier mitliest, aber ich würde ihn bitten den HomebrewKernel auch für das XpressPro zu erstellen. Ist das möglich? Würde auch mithelfen, wenn da irgendetwas benötigt wird. Dieser Kernel wäre schon recht hilfreich für mich.
Dann das was ich eigentlich anhägen wollte: Gibt es ein CWM für das Odys Xpress pro oder eine andere Möglichkeit ein NANDbackup vom kompletten System zu erstellen? Das Xpress pro ist zur Zeit ein Spieltablet für die Kinder, da wäre eine Möglichkeit gut, das ab und zu mal komplett zurückzusetzen.
Wäre für Infos und evlt. Kernel dankbar.
Viele Grüße
killah78
Ich würde vortschlagen, du machst mal das, was Lars in Post #2 vorgeschlagen hat.
Du brauchst für das Build nicht mehr als den Xpress Pro Kernel und vielleicht noch einen der Sensor Fixes.
Danach ist das Tab dann auf Stand, inkl. CWM.
2014/01/23
Hi Oma,
OK cwm ist schon drin, verstanden. Wegen dem kernel ging es mir darum, dass der mit 1100 läuft. Das sind immerhin 10% schneller. Weil das tablet von der Leistung her ja sehr begrenzt ist. Aber ich werde dann vorerst mal den stock kernel verwenden.
Danke für die info.
Gruss
Killah78
Ja Deutsch ist vollkommen ok.
Wir sind es ja auch
Schön wenn es erstmal läuft.
Vielleicht schaffen es ja mal unsere Kerneler nen Kernel zu bauen.
Aber momentan sind wir echt bussy und haben unsere Priorität auf CM-11.0 aka Kitkat.
Viel Spaß mit CM-10.1
netlars
2014/01/23
gestern abend mit Stock-Kernel geflashed. Habe dann auch den richtigen Sensorfix gefunden. Soweit alles gut.
Aber ich habe ein Problem mit dem Speicher. Ich sehe jetzt nur noch 1,4 von den 8GB als "Interner Speicher". Daneben sehe ich auch die SD-Karte als "Interner Speicher". Der Rest ist nicht sichtbar. Gibt es hier auch sowas wie ein intSD2Nand oder sowas? Oder was muss ich hier tun?
Gruss
killah78
70 Guest(s)
Devices in use: Desktop (62), Phone (8)
