2013/02/27
This Script must be placed in /etc/init.d with a "high" number : "90Zram"
If the kernel supports Zram (youhave to Add CONFIG_ZRAM=y; CONFIG_SWAP=y) the CM Zram Settings will work !
In build prop you must have the string "persist.service.zram="
0Â = Disabled
10 = 10% of total ram
18 = 18% of total ram
etc. etc.
this string is modded by CM Zram Settings....
I tested on Crewrktablets_CM_10_1_Rel 1.2.4
Have Fun !
Yatto
#!/system/bin/sh
# ZRAM activation
# Copyright (C) 2012 The CyanogenMod Project
#Â Â Â Â Â Author: Humberto Borba <humberos@gmail.com>
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
#Â Â Â Â Â http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
### Zram Reset
busybox echo 0 > /sys/block/zram0/disksize
busybox echo "[ZRAM]: DISABLING";
busybox echo 1 > /sys/block/zram0/reset
busybox echo "[ZRAM]: OFF";
ZRAM="persist.service.zram"
if [ "$(getprop $ZRAM)" = "0" ]; then
   busybox echo "[ZRAM]: NOT ACTIVATED.";
   exit 1
else
   busybox echo "[ZRAM]: INIT";
   if ! busybox test -e /sys/block/zram0/disksize ; then
       busybox echo "[ZRAM]: ERROR unable to find /sys/block/zram0/disksize";
       busybox echo "[ZRAM]: NOT ACTIVATED IN KERNEL.";
       exit 1
   else
       ZRAM_VALUE="$(getprop $ZRAM)"
       busybox echo "[ZRAM]: ZRAM_VALUE $ZRAM_VALUE";
       DISKSIZE_VALUE="$(getprop $DISKSIZE)"
      MEMTOTAL="$(grep MemTotal /proc/meminfo | awk ' { print $2 } ')"
       busybox echo "[ZRAM]: MEMTOTAL $MEMTOTAL";
      let "DISKSIZE_VALUE=MEMTOTAL*ZRAM_VALUE/100*1024"
       busybox echo "[ZRAM]: DISKSIZE $DISKSIZE_VALUE";
       if (( "$DISKSIZE_VALUE" > 0 )) ; then
           busybox echo "[ZRAM]: Setting ZRAM disksize.";
           busybox echo $DISKSIZE_VALUE > /sys/block/zram0/disksize
           busybox echo "[ZRAM]: Starting ZRAM.";
           busybox mkswap /dev/block/zram0
           busybox swapon /dev/block/zram0
           busybox echo "[ZRAM]: ACTIVATED.";
       else
           busybox echo "[ZRAM]: Invalid Disk Size.";
           exit 1
       fi
   fi
fi
exit 0
The following users say thank you to yattodettaman for this useful post:
netlars
2012/11/19
Hi Yatto,
many thanks for the script, looks nice especially for our old low ram tablets!
2012/11/19
One more question, for swapping a swap partition is needed?
2012/11/19
Fine..
do you know what happens if a ZRAM enabled kernel is used on a Rom without ZRAM support?
I'll only ask because if we make this changes to our kernel base, then it would be bad if we had to have two kernel defconfigs and kernel builds, one for ZRAM enabled build and one for the older ones.
I think that it makes no difference, but only to be sure..
2013/02/27
If you have a kernel with zram enabled, but you have a rom without zram support, simply you don't use zram. It's like you have Zram disabled in cm10.1 zram settings with the kernel with zram support
if you look at the script, there are two lines
If you don't run these command it's like you dont'have zram kernel. The Ram is not allocated.
I think you can make a base kernel with zram support.
Try and test.
2012/11/19
You can be sure that I will do that.
Many Thanks for this!
2012/11/19
not me, but I made a zRam enabled XPress kernel for Netlars...
Really nice, it works fine!
We put this into the next CM10.1 release, and I will rebuild all custom kernel with zRam enabled the next days.
2012/11/19
Hi Yatto,
now I can give a personal feedback.
I have installed the CM10.1 with my new zRam enabled homebrew kernel on the Odys NeoX8.
And what could I say, it's amazing!! Never seen it so responsible, it works like a charm.
Great work!
67 Guest(s)
Devices in use: Desktop (61), Phone (6)
hans41
rickybk
soniya07
ironmangitar
