2012/11/19
I'm sorry, but as far as I know there more differences between G2 and G3.
As far as I can see on their Homepage, they have a 10G2 release for the kernel, perhaps it can help us to make a custom kernel. But please, that are old sources, don't know if the config could be transfered.
Here is a 3.0.8 kernel for the Arnova 10 G2:Â Arnova10G2_308_kernel_20121121.zip
Linux version 3.0.8+ (root@sc-development-android) (gcc version 4.4.0 (GCC) ) #329 PREEMPT Wed Nov 21 11:51:41 CST 2012
It's a binary only and we don't have the source code for it.Â
For older 2.6.x kernel, Arnova published the source code here:
http://arnovatech.com/support/GNU/AN10G2_GPL_release.tgz
2013/05/23
Thank you so much for this kernel . Ive replaced the kernel in crewtablets JB 4.2.2 v1.3 14.07.2013 release
and flashed to my 10g2 applied the nand fix and it working nice on my tab . mega jellybean 4.2.2 working on my thourght to be useless archos tab
one little problem im having problems with adb i cant get it to work .windows detects it as android device using the drivers from googles sdk . but command line shows no devices connected , adb is enabled in setting on tablet, i also tapped build tab10 times to show i was developer even though developer menu was all ready visable. ive also tried in Ubuntu added to udev rule but still cant see in adb..
? is it somehow disabled in kernel - how to rectify
Thanks again for link to arnova 10g2 kernel
change storage mode from mass storage to mtp. And then adb works.
netlars
2013/05/23
Ive tried changing usb modes . and it does detect adb interface, device manager installs driver.
open cmd prompt in C:\adt-bundle-windows\sdk\platform-tools adb devices show nothing connected..
i give up trying adb over usb as all those id`s in etc/usb_modeswitch.d gave me a migrain
but realy could do with getting it working as unable to logcat the device as it boots up.
ps i am able to get adb connection over tcp wirelessly
on tab in shell window adb tcpip 5555,stop adbd,start adbd
on laptop adb connect tabs-ip:5555
pss
In the rom crewtablets JB 4.2.2 v1.3 14.07.2013 the folder /etc/usb_modeswitch.d .which files relate to my AN10G2 as they dont seem to correspond to the driver id detected in device manager
78 Guest(s)
Devices in use: Desktop (66), Phone (11), Tablet (1)
lokeshreddymtpl
scoopsat
Mikewood
XSTR
aldi_2003
dtcinfly
