Screen Rotation with RK29 AOSP 4.2.2_r1.2 Testbuild
wiedemer
Forum Posts: 14
61
2013/08/19 - 20:26
I dont think so.
It is "crew rktablets" red-lighted from left to right.
62
2013/08/19 - 20:33
Upps, you are not on the latest build?
Can you pls check out this here: http://crewrktablets.arctablet.com/?p=1661
Just as is and if needed with the first downloaded fix?
wiedemer
Forum Posts: 14
63
2013/08/19 - 20:38
ouh. I tried those Multi-Window-Version and didnt like it...
So I wiould like to use your V1.5
(Also because in this version SIP is fine for my provider...)
64
2013/08/19 - 20:52
Ok, last try: http://crewrktablets.arctablet.com/?wpfb_dl=887
wiedemer
Forum Posts: 14
65
2013/08/19 - 21:04
still 90° ahead.
66
2013/08/19 - 21:11
Ok, then I have not enough sources to get it right.
Pls try fixes from post #16. Also:
- Xirion Excellent 8 http://crewrktablets.arctablet.com/?wpfb_dl=885
- Mediacom 810c http://crewrktablets.arctablet.com/?wpfb_dl=883
- Odys Next http://crewrktablets.arctablet.com/?wpfb_dl=859
Maybe you have luck.
wiedemer
Forum Posts: 14
67
2013/08/19 - 21:56
OK. Tried the last 3 and the other 5 from post #16.
Still no luck.
But anway: Thank you for your time.
Ralf
68
2013/08/19 - 22:39
Odys Xpress Pro: 8" 1024*768 (4:3), capacitive touch 5p, Goodix_GT801-TS, RTL8188 WLAN on USB11, MMA7660 Sensor, RT5631 Audio, OV7675 fcam, OV2655 rcam, ANX7150 HDMI, TPS65910 clock
One more idea: the generic MMA7660 fix
http://crewrktablets.arctablet.com/?wpfb_dl=219
http://crewrktablets.arctablet.com/?wpfb_dl=348
http://crewrktablets.arctablet.com/?wpfb_dl=637
wiedemer
Forum Posts: 14
69
2013/08/20 - 18:50
Hi Oma,
still no success.
With the first 2 nothing changed.
With the last one "CrewRKTablets_CM10.1_Sensor_90_Degree_Fix" I had the same crazy behavior than in post #55.
70
2013/08/20 - 19:29
Ok, sorry about that. Maybe it is worth to think about plan B.
Fix screen by top menue (PhabletUI only): http://crewrktablets.arctablet.com/?attachment_id=1620
or with this nice app: http://forum.xda-developers.com/attachment.php?attachmentid=1385340&d=1349707755
wiedemer
Forum Posts: 14
71
2013/08/20 - 20:38
I give up.
Today I also tried your latest version of the Multi-Windows.
1st: "As Is": Same issue
2nd: Installed: "CrewRKTablets_JB4.2_multi-window_Modell_fix_Odys_Xpress Pro".: Same Issue
3rd: Installed: apk "Rotate v2.0": Same Issue with each option...
4th: give up: will probably be the best...
No Success anyway.
Unbelievable.
wiedemer
Forum Posts: 14
72
2013/08/24 - 15:12
Because of my Ambition I couldn´t give up.
Tried everything.
Find NO ROM, Patch or App that fixes those screen-issue.
@OMA: In your latest build I switched off the Multi-Window-Function, so those Build is also an interesting one.
But still no change to get the display at least fixed in Portrait...
Ralf
73
2013/08/24 - 15:23
With the app Rotate you can fix the srceen in any direction.
max20091
Viet Nam
Forum Posts: 25
74
2013/08/25 - 11:16
im go back to your ics rom because your new multi-window rom running too slow :(  .
can you explain this stripe error?Screenshot_2013-08-25-10-37-45-1.pngImage Enlarger
Edit: all my odys next tablet get this error!
75
2013/08/25 - 13:02
You mean the effect is given on all firmware?
143 Guest(s)
Devices in use: Desktop (133), Phone (10)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
