Screen Rotation with RK29 AOSP 4.2.2_r1.2 Testbuild
max20091
Viet Nam
Forum Posts: 25
46
2013/08/08 - 03:48
Can you make a rotation fix on multi_window build for me? Im using your hombrew kernel.
max20091
Viet Nam
Forum Posts: 25
47
2013/08/10 - 13:56
im waiting for 2 days but no quote or reply. Someone help me please! :(
48
2013/08/10 - 14:35
max20091
max20091
Viet Nam
Forum Posts: 25
49
2013/08/10 - 14:55
Try this: http://crewrktablets.arctablet.com/?wpfb_dl=859
it working perfectly :) but some app shortcuts run out of screen when i downloaded apps from google play :( . Can you make for me a fix?
And can you test it for me this fix ;) ? im fixed some errors from your 4.2.2 fix :p !
50
2013/08/10 - 15:08
This is a generic fault in JB builds. They use 600px instead of 720px.
Use one of the other launcher.
max20091
max20091
Viet Nam
Forum Posts: 25
51
2013/08/11 - 13:23
hi OMA. can you make for me a extSD to NAND fix?
my fix working wrong like this:I lost apps if I set the apps on the SD card.
I can't fix that error :(
wiedemer
Forum Posts: 14
52
2013/08/15 - 20:33
Hi OMA,
your V1.5 works great on my ODYS XPRESS.
Finally the SIP-Stack works. GREAT!
But I still have the rotation-problem on the Tablet.
I tried all fixes I found on the arctablet.com - Site and everything I found here. But still no success. Rotation makes me crazy....
Would be fine to get a fix.
Thanks again
Ralf
53
2013/08/15 - 20:42
Which kernel? What is exactly the problem after first boot?
wiedemer
Forum Posts: 14
54
2013/08/19 - 17:59
Kernel: kernel_308_xpress pro_odys from 15.06.2012.
(I think this is the latest STOCK-Version).
All the others I tested the ODYS after NAND-Flash started with a lighted screen, but nothing in it. Also 30 minutes waiting didnt help. No start-screen.)
After the first boot it comes up as expected.
Then I rotate my ODYS XPRESS 90°. Screen rotates 180°.
Then: Every time I rotate, screen rotates 90° or 180°.
It is a challenge to rotate it to show the screen right.
(Turning really quick for 180° sometimes helps in Portrait, so that it fits.)
Ralf
wiedemer
Forum Posts: 14
55
2013/08/19 - 18:30
Now I flashed once more to describe it better after the first start:
I start in landscape when the ODYS lays down on the table - everything is fine.
I move it to the upper position, to be able reading it better, it rotates 90° right, as if I would have moved it in portrait-position.
Then, during I hold it in the upper position and move it left, it stays.
This means, portrait is fine.
I move it next left to landscape, it roates 180°.
Next left move into portrait position, rotation 90° into landscape...
One more move it is fine.
56
2013/08/19 - 18:40
Ok, Odys Xpress Pro not Xpress.
Pls test that: http://crewrktablets.arctablet.com/?wpfb_dl=886
wiedemer
Forum Posts: 14
57
2013/08/19 - 19:25
Now it constantly is 90° faster than I am...
wiedemer
Forum Posts: 14
59
2013/08/19 - 20:19
exactly the same. Rotation is 90° ahead
60
2013/08/19 - 20:21
Has boot-animation changed the direction?
144 Guest(s)
Devices in use: Desktop (136), Phone (7), Tablet (1)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
