Screen Rotation with RK29 AOSP 4.2.2_r1.2 Testbuild
yattodettaman
Forum Posts: 36
Thanks Received: 13
31
2013/07/24 - 10:43
Hi Oma,
  You're right ! The smallest version is better in Phablet UI !
But in TabletUI (the TestBuild 1.3 is in TabletUI), is better the bigger version, specially at 120DPI !!!!!!!!
By the way, good Works for th Sdk 2 !   when the porting on rk29 ?!?!? :)
bodoadferne
32
2013/07/24 - 10:46
bodoadferne said
Good work. I will test this build in the next few days more. If I will find any bugs, i will report it here or open an issue
thanks so far... good work guys!
OK, one Bug found. The battery indicator always shows 95 %.
Issue is already created.
greetings
max20091
Viet Nam
Forum Posts: 25
33
2013/07/25 - 19:03
Sorry for my bad english.
I have a odys next and work good with your AOSP rom but there is something work wrong:
1. My camera is upside down
2. The battery never get over 95% and not recharging if i shut down the tablet, JB 4.1 rom not like that.
3.if i take the tablet landscape, the tablet rolation to reverse portrait, and the tablet rolation very slow.
4. I just got 1.17GB/16GB NAND FLASH with your nand fix?
5. The master key not fixed, you can find master key dual fix to fix that error.
How i can fix first 4 errors?
max20091
Viet Nam
Forum Posts: 25
34
2013/08/02 - 14:53
Someone help me please
35
2013/08/02 - 18:52
Pls check out the latest build v1.5 - http://crewrktablets.arctablet.com/?p=1291
or if you'd like the multi-window build - http://crewrktablets.arctablet.com/?p=1661
120.pngImage Enlarger
109.pngImage Enlarger
max20091
max20091
Viet Nam
Forum Posts: 25
36
2013/08/03 - 03:29
Can you make me a fix on multi-window build? My tablet name is odys next.
And can you upload your rom build tools? So i can make some optimized build from your rom.
37
2013/08/03 - 08:33
An Odys Next in Vietnam? Wow ;-)
Just change Loox to Next in build.prop. Use FilemangerHD (enable mount / as writeable in settings).
max20091
max20091
Viet Nam
Forum Posts: 25
38
2013/08/03 - 15:50
hi oma, i just update your rom and use the nand fix but i just got 1.17GB/16GB , can you make me a fix so i can got all 16gb?
39
2013/08/03 - 16:06
Did you use the right kernel?
Kernel Odys Next: http://crewrktablets.arctablet.com/?wpfb_dl=143
or homebrew kernel Odys Next: http://crewrktablets.arctablet.com/?wpfb_dl=357
max20091
Viet Nam
Forum Posts: 25
40
2013/08/03 - 16:22
im using fr3tsOnKernel from this website :( : http://www.android-hilfe.de/root-custom-roms-modding-fuer-odys-next/329991-next-kernel-mit-24-1100mhz-bluetooth-tester-gesucht.html
And can you make for me a rotation fix? Thanks :)
Im online on the tablet :)
Im so sleeping! It 22:00 in vietnam
bodoadferne
41
2013/08/03 - 19:47
Modelfix for PMP 5097 not working! Old Problems are Back, wrong Screen Rotation Tablet Landscape -> Display Vertical, Tablet Vertical --> Display Landscape. Battery inidcator seems to be working.
max20091
Viet Nam
Forum Posts: 25
42
2013/08/04 - 01:55
Did you use the right kernel? Kernel Odys Next: http://crewrktablets.arctablet.com/?wpfb_dl=143 or homebrew kernel Odys Next: http://crewrktablets.arctablet.com/?wpfb_dl=357   - Oma -
now im using your homebrew kernel, last night my tablet was crazy with LCD Density Modder
thanks for your multi-window build and i will update your new rom
im updated your new rom but it seems the new installed apps on google play created a shortcut, but i can't see the shortcut. how i can fix it. i will post my pictures about that error
adriannarn
Moldova
Forum Posts: 14
43
2013/08/04 - 17:51
Hi, I tried the last build. Only 2 issues - libwebcore.so and battery icon.
I tried changing BatteryService.java in classes.dex with the one from JB 4.1.1 - tablet gets stuck at bootanimation. Any chance to make this work?
max20091
Viet Nam
Forum Posts: 25
44
2013/08/04 - 18:08
You will have a chance to fix your error, but sorry, im not good at cwm :( , please talk to oma and he will make a fix for you ;) .
45
2013/08/07 - 18:07
yattodettaman said
Hi Oma,
Done ;-)   http://crewrktablets.arctablet.com/?p=1661
May I ask you to adopt the build and release a xteam build for Mediacom (810, 820) tabs?
That would be very nice!
croccio said:
hi! i've a mediacom 810c (rk29 tab) and i've flash your android 4.2.2 multiwindow but if i flash xteam kernel rotation wont work. can you make a flashable zip to work rotation with xteam kernel please? thank u and sorry for my english
max20091
142 Guest(s)
Devices in use: Desktop (131), Phone (11)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
