Screen Rotation with RK29 AOSP 4.2.2_r1.2 Testbuild
2013/07/18 - 22:57
Model fix for use with v1.3 (install via CWM).
download fix and try again:
- Intex Itab 12T065
- Prestigio PMP 5097C pro
- Arnova 8c G3
- Airtab m971w
- MSI Enjoy 7plus
adriannarn
Moldova
Forum Posts: 14
2013/07/19 - 11:07
I tried the 8cg3 fix on my 8g3, rotation works correctly. The other issues remain the same, plus after installing the fix, internal memory and nand flash have the same size - 1.44 Gb.
In case you need it, I attached a dmesg
synescu
2013/07/20 - 13:09
hy oma, eni model fix four pascal2 or alcatel t10 in plean? with v1.3 onli problem rotation in landscape mod
thanks
yattodettaman
Forum Posts: 36
Thanks Received: 13
2013/07/22 - 17:16
Hi guys.
Very compliments to get fully working rk29 tablets ! good work !
I've tested testbuild1.3 on smartpad 810c with my kernel and it works great !
i have some questions for you, if you 'd like to answer..... :D
1) the font of clock in the bottom right cornet is too small for me.... can you make bigger ?!! :D
2) In the logcat there are too "cannot dequeue buffers" error....  these errors can slow the pad ?!?
3) how to set phablet UI ?!?!?
thanks !
have a nice day !
Yatto
JochenKauz
Forum Posts: 450
Thanks Received: 76
2013/07/22 - 21:50
Hi Yatto,
nice to see you hear at our small place!
JB 4.2.2 is at this moment a beta, and we are working on several issues to make it out of beta stage.
Point 1 is one of these issues, for the other ones, I'm not sure, Netlars could answer it better.
JochenKauz
netlars
Forum Posts: 149
Thanks Received: 29
2013/07/23 - 07:01
Hi Yatto,
thanks for your answer.
Point 1, please open an new Issue: Issues from rk29 AOSP 4.2.2_r1
Point 2, I know what you meen, also open an new Issue please
Point 3, Tablet UI is hard coded at the moment
yattodettaman
Forum Posts: 36
Thanks Received: 13
2013/07/23 - 08:41
Hi Netlars..... how i can open a new issue on your blog ??? :O
netlars
Forum Posts: 149
Thanks Received: 29
2013/07/23 - 08:55
yes, you can do it.
here is the link again: Issues from rk29 AOSP 4.2.2_r1
yattodettaman
Forum Posts: 36
Thanks Received: 13
2013/07/23 - 09:40
Hi netlars,
  i found this patch.....   to resolve the dequeue buffers error....
https://github.com/epinter/atrix-cm10-patch/blob/master/frameworks_native-05-dequeuebuf.patch
to add an issue, sorry, but a can't find "HOW TO".... i have only "change filter"  and "remove all filters" buttons....   ho to add an issue ?!?!?!
To fix the small clock size in system bar, i tryed to change (looking at the systemui.apk from CUBE 4.2.2) in systemUI.apk in the file res values stiles.xml :
1st Section:
    <style name="TextAppearance.StatusBar.Clock" parent="@*android:style/TextAppearance.StatusBar.Icon">
        <item name="android:textSize">16.0dip</item>      !!!! I changed with 22.0dip !!!!!
        <item name="android:textStyle">normal</item>
        <item name="android:textColor">@*android:color/holo_blue_light</item>
    </style>
    <style name="TextAppearance.StatusBar.Date" parent="@*android:style/TextAppearance.StatusBar.Icon">
    </style>
2nd Section:
<style name="TextAppearance.QuickSettings.Clock" parent="@style/TextAppearance.QuickSettings.TileView">
        <item name="android:textSize">20.0dip</item>     !!!! I changed with 22.0dip !!!!!
    </style>
    <style name="TextAppearance.QuickSettings.Date" parent="@style/TextAppearance.QuickSettings.TileView">
        <item name="android:textSize">14.0dip</item>     !!!! I changed with 22.0dip !!!!!
    </style>
    <style name="TextAppearance.QuickSettings.Alarm" parent="@style/TextAppearance.QuickSettings.TileView">
        <item name="android:textColor">#ff3a3b39</item>
    </style>
3rd Section:
<style name="TextAppearance.StatusBar.PhoneTicker" parent="@*android:style/TextAppearance.StatusBar.Ticker">
    </style>
in the file res values-sw720dp stiles.xml :
<style name="TextAppearance.SystemBar.Expanded.Date" parent="@style/TextAppearance.StatusBar.Expanded.Date">
        <item name="android:textColor">#ff666666</item>
        <item name="android:textAllCaps">true</item>
    </style>
2013/07/23 - 18:29
Hi yatto,
long time no see ;-)
The clock is that small because the clock must fit also in phabletUI (top bar).
danielsolis87
2013/07/23 - 18:33
- Intex Itab 12T065
- Arnova 8c G3
- Airtab m971w
- MSI Enjoy 7plus
Hi, there are any fix for BQ-Kepler2, thnx.
netlars
Forum Posts: 149
Thanks Received: 29
2013/07/23 - 19:49
I see the button on the top of first Issue: Report new Issue
Please test another browser.
bodoadferne
2013/07/23 - 23:16
netlars said
Yesterday, I'm upload a new build: http://crewrktablets.arctablet.com/?p=1291
Hello "CrewRKTablet" guys!
the new build and the modelfix for pmp5097 are running... Sorry for the late feedback, i was on holidays so i could not flash my tablet to test the fix and build earlier.
Back to the Build:
  • Screenrotation works
  • UI feels snapy
  • Youtube works, i can see and hear the video
  • Camera Works...
  • no crash of any apps untill now
Good work. I will test this build in the next few days more. If I will find any bugs, i will report it here or open an issue
thanks so far... good work guys!
yattodettaman
Forum Posts: 36
Thanks Received: 13
2013/07/24 - 08:58
Hi yatto,
Hi Oma,
  nice to see you ! :)
I'm telling you that  I fixed the small clock, modding the files in systemUI.apk, as i wrote in previous post !!!.
It looks good in tabletUI
In PhabletUI is better the original SystemUI.apk.
If you wanna test it :  SystemUI.zip
Bye,
Yatto
The following users say thank you to yattodettaman for this useful post:
2013/07/24 - 10:28
Thanks, yatto. Have tested that. And for me the smaller version fits better.
Anyhow, thank you for working with us!
007a.pngImage Enlarger007.pngImage Enlarger
144 Guest(s)
Devices in use: Desktop (134), Phone (9), Tablet (1)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
