2013/07/08
I have installed this ROM on my Prestigio PMP5097. Everything seems to work fine, except the screenrotation. i always stuck in landscape mode. It seems the g-sensor are not working eg. queried. Ive tried to install the 90-degree fix, but this wont help. Also tried to installed the modefilx for the 1.2 JellyBean - doing this the tabled will stuck at the android boot animation. Any change to get the screen rotation working?Â
By the way, cool ROM and good work - go on with it....
Don't use old fixes.
Ok, can you upload an dmesg please?
netlars
2013/07/09
Prestigio pmp5097cpro not work rotationÂ
DmesgÂ
http://rghost.ru/private/47319480/20863164ab7165ac96ff5a8403051c7b
netlars
2013/07/10
Hello, i just have tried to flash my Prestigio PMP5097Cpro with this ROM, but unfortunately after step "Info: run ok" in RKAndroidTool nothing happens, only connection between RKAndroidTool and Tablet gets lost.
I disconnect from PC and try to turn on the tablet but no reaction at all, screen keeps black.
What am i doing wrong? I have changed the kernel file to a stock kernel that i downloaded from OMAs repository.
Anything else i need to consider? How shall the device be bootet after flashing? Keep cable connected to PC?
Any button combination to be pressed?
Thanks for your help!
2013/07/09
netlars said
Here is the first test. I'm edit the name of the daemon.Â
Download sensors.rk29board.so_.7z not work again :-[Â
2013/02/14
Hello. Arnova 8g3.
1. Akku shows no info.
2. Camera isn't working(when I try to open the camera app it says "can't connect to the camera").
3. Incorrect screen rotation. When the device is in landscape the screen rotates to reverse portrait Another problem, related to the interface. I noticed it while wiewing my email in boat browser and then in a txt file viewer. It appears only in specific applications.
Here's a screenshot- http://i40.tinypic.com/2hr1wfm.png
Nevertheless,
Nice ROM bro, keep it going:-)
Model fix Arnova 8cG3: http://crewrktablets.arctablet.com/?wpfb_dl=775
@netlars: we need to patch services.jar - code is here: http://www.arctablet.com/blog/forum/arnova-8-g2/morkamodjb-v1-00-all-model-g2-and-g3/page-2/#p14712
I know, it is on to do list
netlars
2013/07/09
http://rghost.ru/private/47388220/7b4f988ccba571eb7087e5eb272ad6b1
Install modelfix, rotation for 90°  Not work youtube, constantly updated calendar, builds an image in the browser.
Yesterday, I'm upload a new build: http://crewrktablets.arctablet.com/?p=1291
netlars
Internal SD dosn't work, when you forgett install the Format NAND fix.
The modell fix, test it! I don't know.
The following users say thank you to netlars for this useful post:
adriannarnnetlars
64 Guest(s)
Devices in use: Desktop (51), Phone (13)
forty42
samih
macsierra2
sachatanya
Nursat
MaXXWar
