We need the tab specific kernel. Is the stock firmware available?
2014/08/11
The kernel is listed below I got it under proc/version
(Linux version 3.0.8+ (fb@sc-development-android)(gcc version 4.4.0 (GCC)) # 175 PREEMPT fri Sep 28 20:5327 CST 2012
In regards to stock firmware no.. Searched everywhere no dice.... I suspect  that I may do something like install clockwork mod, and do a image dump... Before I do that do you recommend a version of clockwork mod that is pretty safe, and can be installed via the recovery mode, or suggest another method to try and get an image? I cannot connect via USB cable, during recovery mode to see it I can do some ADB commands... The pc does not recognize it or even show it as a unknown device. though after it boots I do see it as another USB drive.
Thanks!
Download a Terminal Emulator from Play Store. Boot the tab fresh and type:
su
dmesg >/mnt/sdcard/dmesg.txt
cat proc/cmdline >/mnt/sdcard/cmdline.txt
cat proc/mtd > /mnt/sdcard/mtd.txt
Upload the files. I will check.
Ok, next is to dump the firmware:
dd if=/dev/mtd/mtd1 of=/sdcard/kernel.img bs=4096
dd if=/dev/mtd/mtd2 of=/sdcard/boot.img bs=4096
dd if=/dev/mtd/mtd3 of=/sdcard/recovery.img bs=4096
dd if=/dev/mtd/mtd8 of=/sdcard/system.img bs=4096
Upload the files to a file hoster and post the link here. I will check.
Hm, you did a dmesg log. So you must have lost su rights in the meantime. Look at the Superuser app if the terminal still have permissions.
2014/09/05
Hey guys.
First, sorry if I should have posted this in another topic/forum, but I couldn't find anything for my particular device.
Lexibook Tablet Master 2 MFC157NOÂ
rk2928
ARM Cortex-A9
Mali-400 MP
I have successfully rooted, and flashed CWM-recovery v6.0.3.1 (Followed guide from xda/androtab.info).
My question is: would my device be compatible with anything ?
https://www.dropbox.com/s/kkcmmvtyjm203n5/cmdline.txt?dl=0
https://www.dropbox.com/s/4m4d2z1nzw2v4uq/dmesg.txt?dl=0
https://www.dropbox.com/s/k257chx0pisk3o0/mtd.txt?dl=0
https://www.dropbox.com/s/7vceueiubnumasd/kernel.img?dl=0
https://www.dropbox.com/s/yuikqzbsihzk2tm/boot.img?dl=0
No, the rk2928 was never supported by the community. Sorry.
Reptilez_DKPer aspera ad astra, we rock the Tablets !
Currently Online: jessicapeterson
70 Guest(s)
Devices in use: Desktop (58), Phone (13)
xxxdddd
xxxddd
Kaydc__
jessicapeterson
Riki111
andre92
