2013/12/29
hello,
I am trying to port Ubuntu from here : http://crewrktablets.arctablet.com/?p=1103 on to Craig CMP741D (RK2918)
the CWM included does not have touch support for my device so I can not get beyond CWM screen.
I follow instructions here: http://forum.xda-developers.com/showthread.php?t=2318728
I use it with updated V01.2 and Kernel 308 Odys Loox Ubuntu 201306151204 UbuntuTouch V1.1 because the Odys Loox Kernel is the one that Oma used here http://forum.xda-developers.com/showthread.php?t=1903745 and MasterMind278 adapted here: http://www.androidtablets.net/forum/craig-tablets/53810-tutorial-cmp741d-jellybean-install.html to make custom ROM with JellyBean for my tablet and that is working on this CMP741D w/RK2918
it has Oma CWM for Genio - v5.5.0.4 Touch working. I try RKAndroidTool and change recovery.img to this but then it hangs on black screen at boot.
I think if somehow the CWM included with the Ubuntu from RKTablets can be adjusted to have touch support then I cant finish install Ubuntu.
can anyone help me to do this? thanks, Happy New Year!
2013/12/29
Bump!
OMA, can you please help about this? I can give more details if needed. Im not sure what to try, learn how to make custom CWM with touch support like the one you made for Genio – v5.5.0.4 or if there is a way to work around it with rockchiptool.
It seems that somehow I should be able to port your touch support mods in Genio – v5.5.0.4 CWM to the CWM that is used in the Ubuntu installer but I dont know if this is possible or if I should try another approach to get this working.
thanks
2012/11/19
you can use on rk2918 this recovery.img instead, it is the touch CWM version:
2013/12/29
JochenKauz said
hi JochenKauz, thank you! can you tell me if this CWM is to be installed with RockChpTool or Update.zip method? because I have only installed two CWM before and each one use different method of install.
I also wonder if capacitive or resistive each require different CWM or if same CWM works for both capacitive and resistive touch screens.
thanks
its the same recovery for both.
Only you can flash this Image with RockchipTool.
netlars
2013/12/29
netlars said
hi netlars, thanks. that helps me rule out that it could be an issue with the type of touch screen.
I will try again and report back hopefully success with the .img JochenKauz suggest.
Currently Online: hststs44
89 Guest(s)
Devices in use: Desktop (74), Phone (16)
hststs44
lokeshreddymtpl
scoopsat
Mikewood
XSTR
aldi_2003
