RK29 Loox JB 4.2.2 Windoof > Link2SD
ovako
2013/08/26 - 17:51
CrewRKTablets RK29 Loox JB 4.2.2 Windoof on PMP 5080C PRO with kernel
Crewrktablets Kernel 308 Bq-kepler2 201302261455 JB422;
cant mount sdext2 by Link2SD as EXT4 - as EXT3 is ok.
Link2SD reports that format is not supported by system and doesnt create mount script???
Tried mounting EXT4 by script - nothing; any subscriptions for this?
2013/08/26 - 22:07
Why using such dangerous tools? Swap the mount points and you will have plenty of space.
ovako
2013/08/26 - 22:43
Thanks for your prompt answer,
I've been using Link2SD with the other roms too, nothing dangerous so far.
Just wanted to upgrade second partition, since system, data and cache is runing on EXT4, but it cant be mounted?
So what is your suggestion, extSD to NAND fix?
55 Guest(s)
Devices in use: Desktop (47), Phone (8)
