2013/08/07
I've installed the RK29: JB 4.2.2 Multi-Window (Backport of RK31 Chuwi V88 Multi-Window build to RK29 Odys Loox) on my SlidePad70C with the "format_NAND_fix" and the Kernel made available by Oma (on the forgotten project).
The three things (two i've solved )
1) The screen rotation wasn't working so I've made this "fix" based on Oma fix for the 4.1.1 and now works just fine;
2) The lcd density must be changed to 120 otherwise the touch bar is not available (the fix mentioned on my first point also change from 160 to 120);
3) The battery indicator doesn't work, does not show the discharge or the charge of battery, it stays stuck on the value that the battery has on the power on ...
Any idea fix for the battery problem?
Besides that the rom works just fine, i think that the 4.1.1 its faster but ... still testing
Tablet: SlidePad704C
47 Guest(s)
Devices in use: Desktop (35), Phone (12)
hellander
elousstad
relaytester
revoltown
tdomnic024
