2013/11/02
Hello everybody!
I'm planning to use "Crew RKTablets Loox CM10.1 v1.2" on my Arnova 9G2.
I'm looking for a way to patch this Rom with a OpenPDroid Patch to enable Apps like PDroid Manager to set the permission of the apps manually.
Until now I have a Lubuntu system running with which it is possible to compile a OpenPDroid Patch for CM Roms which are in CWM flashable zip format. For example I compiled a OpenPDroid Patch for CM10.1 on my Galaxy S2. The program which patches the Rom is the Auto-Patcher from XDA-Thread, see here: http://forum.xda-developers.com/showthread.php?t=1719408 Thanks to the developers! The Autopatcher compiles a CWM flashable zip file which adds PDroid support for the particular ROM. I've noticed that the cRoms of the RK2918 devices have another way to flash than Samsung devices...
Is it possible to download a CWM flashable zip file of the mentioned Rom "Crew RKTablets Loox CM10.1 v1.2" to patch it with the Auto-Patcher?
I'm quite used to flashing but my compiling skills aren't that good...
Thanks for any help!
Daniel
57 Guest(s)
Devices in use: Desktop (48), Phone (9)
