Oma ROM for the U10GT2 from 51cube?
Do you think it would work?
Spigaw
Lyon
Forum Posts: 32
31
2014/01/08 - 21:04
Both kernels make the tablet bootloop, but I see the green splash (it's flashing too)
JochenKauz
Forum Posts: 450
Thanks Received: 76
32
2014/01/08 - 21:20
Interesting..
The first kernel is the Uzone F4 that worked before.
Please describe exactly(!) what steps did you do for flashing the rom, and I mean really every little step, cause that is impossible for me, first the kernel worked and then you get a bootloop.
Spigaw
Lyon
Forum Posts: 32
33
2014/01/08 - 21:32
Everytime the same procedure :
  1. Rktools ==> Erase IDB (nothing ticked)
  2. Rktools ==> Everything ticked
  3. When trying new kernel :
    • Ticking Parameter and kernel
    • Flash
    • Reboot
Spigaw
Lyon
Forum Posts: 32
34
2014/01/08 - 21:37
Mmmh... Even the one that worked on first hand doesn't work. I'm restoring the tablet on vanilla firmware, then I'll try to reflash everything.
Spigaw
Lyon
Forum Posts: 32
35
2014/01/08 - 21:47
I'M A FKIN DUMBASS.
This tablet does NOT charge via the USB port... So it was discharged. Just stupidly discharged. Can you believe this? I realized it when I saw the vanilla firmware bootlooping. So now I'm trying to boot it, then I'll try your kernels afterwards.
Yell
JochenKauz
Forum Posts: 450
Thanks Received: 76
36
2014/01/08 - 21:59
Hey,
no problem... just let this thing going to work.
Spigaw
Lyon
Forum Posts: 32
37
2014/01/09 - 18:12
WiFi in sight! It's working and even connecting! Hurray! (this kernel worked : http://crewrktablets.arctablet.com/?wpfb_dl=1365)
The following users say thank you to Spigaw for this useful post:
JochenKauz
JochenKauz
Forum Posts: 450
Thanks Received: 76
38
2014/01/09 - 18:30
Perfect...
First Kernel was the Uzone F4 kernel and second one was the kernel with changed wifi driver.
So as far as I can see there are 2 more problems to solve
1. audio is not working
2. the tablet keys are wrong?
Spigaw
Lyon
Forum Posts: 32
39
2014/01/09 - 18:50
OK, here are the problems :
Hardware :
  1. Audio is not working
  2. Bluetooth is not working
  3. Only the On/Off button is working. Can we map Vol+/Vol- on the two other ones?
Software :
  1. The rotation is really slow to activate (10 seconds)
  2. I can't add a Google account to the Play Store without the tablet crashing
  3. The tablet is really slow
  4. The touchscreen is a bit offset and slow to respond to touch contact
  5. Rebooting from CWM doesn't work
  6. SD mounting works 1 time out of 10
  7. The battery level fix didn't work, the tablet shows a 100% battery all the time.
JochenKauz
Forum Posts: 450
Thanks Received: 76
40
2014/01/09 - 19:10
Something we can work on.
First question.. You did install format_nand Fix?
Spigaw
Lyon
Forum Posts: 32
41
2014/01/09 - 19:14
Yup, used the fix from the CM10.1 page (http://crewrktablets.arctablet.com/?wpfb_dl=635)
Spigaw
Lyon
Forum Posts: 32
42
2014/01/13 - 23:55
Do you think it would be possible to install the Oma CM7 on it? I don't think the config of this tablet will ever be capable of running any 4*+ Android version...
JochenKauz
Forum Posts: 450
Thanks Received: 76
43
2014/01/14 - 00:28
First, yes it should be possible to run cm7.
Second, but I think that the problems are caused from wrong config and settings of the kernel, not because the tablet is to old. Look at the Odys Loox, it is also a really old config.
Okay, lets look at the problems:
Hardware :
(not easy, but we could look at dissambler of the old kernel, but a kallsyms would be needed)
(CM10.1 uses a different BT stack, solvable with Yatto's BT fix)
(we could look at dissambler of the old kernel, but a kallsyms would be needed)
Software :
(I think that this is more a problem of heavy cpu load, we have to find the process that uses to much power)
(what gapps did you install?)
(Did you really made a tick before the bootloader?)
(internal or external sd?)
(this should be related to wrong battery driver, I think your tablet uses the adc battery and that could be fixed)
Spigaw
Lyon
Forum Posts: 32
44
2014/01/14 - 08:10
Thanks for your answer :)
I finally managed to add my Google account for the Play Store, no problem with this. The tablet is fully recognized by it, I could install many basic apps (Chrome, Google Keyboard 2.0, ADW...)
For CWM, I just select Reboot now, which does nothing, I have to reset the tablet myself.
I managed to flash the tablet interface instead of the phablet one, too, and it worked perfectly (it's much better, as it comes with built-in soft volume keys on the status bar).
Finally, I'm speaking about the internal SD card, I thought it was the external one. My computer (Win7 64) tells me to format the memory before using it.
I'll wait for your instructions :)
JochenKauz
Forum Posts: 450
Thanks Received: 76
45
2014/01/14 - 13:59
Okay, now step by step..
Cause I think that your config is messed up at this point, no reboot, slow tablet etc., I think we should start a completely new attempt with a really clean install.
Two questions before we start.
1. you want to use an external BT USB Dongle?
2. Standardinstallation of the CM10.1 v1.2.4 is the mounting of external sdcard in gaming mode. This means that mount points for sdcard and data are swapped. In this configuration the external sdcard is treated like the internal sdcard, and the internal is treated as external sdcard. That means that you never could launch your tablet without the external sdcard inserted. The reason for this is, that normally the external sdcard is bigger in size than the internal. But you pay the price that you have the external sdcard permanently inserted (without external sdcard you ran in serious trouble), if not we have to change this.
104 Guest(s)
Devices in use: Desktop (93), Phone (11)
matinf
floki
orocamora
Ellocojoe
Tonysc17
olegator
