Oma ROM for the U10GT2 from 51cube?
Do you think it would work?
Spigaw
Lyon
Forum Posts: 32
2014/01/04 - 10:36
I'm trying the other U10GT kernels from your site, too!
Spigaw
Lyon
Forum Posts: 32
2014/01/04 - 11:23
This piece of crap is driving me mad... I tried to flash CWM alone, but no UI when I try to boot it. The same for every kernel I tried...
Thanks Received: 1383
2014/01/04 - 12:19
The kernel won't work. Is the screen black or are the lights on?
Try this one: http://crewrktablets.arctablet.com/?wpfb_dl=1343 (just tick parameter and kernel).
Spigaw
Lyon
Forum Posts: 32
2014/01/04 - 12:38
It's booting! Trying to flash the fix right now
Spigaw
Lyon
Forum Posts: 32
2014/01/04 - 13:46
The tablet booted on the first ROM you gave me, not the CM build. Working :
- Touchscreen
- Rotation
- Root commands
But can't make the WiFi or Bluetooth working.
There is no volume control (the hardware keys are strange : Power, Menu, Back), they were on the status bar on the Gingerbread build. Anyway, the sound is not working :)
Spigaw
Lyon
Forum Posts: 32
2014/01/04 - 15:54
The CM10.1 build is launching too, with the same problems. If you need me to test anything (new kernel, drivers...) just tell me.
2014/01/04 - 16:03
This is one of our homebrew kernel for tabs never seen a stock 3.0.8+ kernel.
We have screen and touch, which are usually the main problems.
Pls provide a dmesg log.
Spigaw
Spigaw
Lyon
Forum Posts: 32
2014/01/04 - 16:18
Here it is! Thanks for your patience, you are really kind to help me.
Spigaw
Lyon
Forum Posts: 32
2014/01/06 - 15:34
So, if I understand it well, my U10GT2 is the same in hardware as a Uzone Pad?
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/01/07 - 20:29
You're tablet shares a few things with the Uzone F4 kernel, yes.
I'll have to look closer to your original dmesg, to find out the missing parts.
Perhaps I can make a better working kernel for you..
Cheers
JochenKauz
Spigaw
Spigaw
Lyon
Forum Posts: 32
2014/01/07 - 20:41
It is really cool to be in touch with the Android community, I don't know how to thank you for your help :)
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/01/08 - 12:01
Here we go...
First test kernel. I have changed the wifi driver to rtl8192c. the driver mentioned in your original dmesg.
Audio is a little bit more complicated, cause Uzone F4 uses the same audio chip as your Cube. So there must be something different. But not the highest priority I think now.
http://crewrktablets.arctablet.com/?wpfb_dl=1364
Spigaw
Lyon
Forum Posts: 32
2014/01/08 - 18:22
Just tried your kernel, the tablet doesn't boot, I get a blackscreen (with CM10.1). I'm trying with the Oma 4.1.1 ROM right now :)
Spigaw
Lyon
Forum Posts: 32
2014/01/08 - 18:28
The Oma ROM failed too : blackscreen. I'll wait for your feedback :)
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/01/08 - 19:42
Hmm..
I'm a little bit confused, cause it was the source of the kernel that booted before, only change wifi driver..
Does it show a green Logo?
Let's test it again, please flash both:
1. http://crewrktablets.arctablet.com/?wpfb_dl=1366
2. http://crewrktablets.arctablet.com/?wpfb_dl=1365
Both Kernel are for CM10.1 release.
Currently Online: 3nf
97 Guest(s)
Devices in use: Desktop (87), Phone (10), Tablet (1)
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
lesfurets
