2013/12/31
I'm currently using an U10GT2 from manufacturer 51cube, but I can't find any ROM for this thing... It sports the RK2918 chip. Do any of you think I could try to flash the U9GT2 version of the Oma ROM, as it is nearly the same hardware?..
Thanks in advance! Any help really appreciated!
Is the ICS stock firmware available or the tab rooted?
We need a 3.0.8+ kernel. No ICS firmware available?
2013/12/31
That was the biggest problem of this tablet : it was advertised as the first ICS tablet to ship, but the 4.0 version never came. It is almost the same hardware as the U9GT2, the sole difference is about the RAM : 512Mb DDR3 instead of one gig. Do you want me to check the kernel version on the tablet? If so, I'll do it this evening when back home.
Thanks again for your support.
GB comes with 2.6.xx kernel. Can you pls provide a dmesg log? I'd like to see your hardware.
2013/12/31
====================== SYSTEM INFORMATION ===================
[ro.secure]: [0]
[ro.allow.mock.location]: [1]
[ro.debuggable]: [1]
[persist.service.adb.enable]: [1]
[media.demux.cfg]: [Matroska_Wmv_Wav_Flv_Mpg_Mpeg2ts_Avi_Mov_Wma_Rm_Ogg_Mp3_Amr_Aac]
[media.decoder.cfg]: [MP3_AMRNB_AMRWB_AAC_DTS_WMA_AC3_RA_WAV_AVC_RV_FLV_M2V_VC1_G711_M4vH263_Vorbis_VPX]
[opengl.vivante.texture]: [1]
[ril.pppchannel]: [/dev/ttyUSB2]
[ril.function.dataonly]: [1]
[rild.libpath]: [/system/lib/libreference-ril-tdm330.so]
[ro.factorytest]: [0]
[ro.serialno]: []
[ro.bootmode]: [unknown]
[ro.baseband]: [unknown]
[ro.carrier]: [unknown]
[ro.bootloader]: [unknown]
[ro.hardware]: [rk29board]
[ro.revision]: [0]
[ro.build.id]: [GINGERBREAD]
[ro.build.display.id]: [rk29sdk-eng 2.3.1 GINGERBREAD eng.zhansb.20111222.163508 test-keys]
[ro.build.version.incremental]: [eng.zhansb.20111222.163508]
[ro.build.version.sdk]: [9]
[ro.build.version.codename]: [REL]
[ro.build.version.release]: [2.3.1]
[ro.build.date]: [2011? 12? 22? ??? 16:36:17 CST]
[ro.build.date.utc]: [1324542977]
[ro.build.type]: [eng]
[ro.build.user]: [zhansb]
[ro.build.host]: [zGo]
[ro.build.tags]: [test-keys]
[ro.product.model]: [U10GT_2]
[ro.product.brand]: [rockchip]
[ro.product.name]: [rk29sdk]
[ro.product.device]: [rk29sdk]
[ro.product.board]: [rk29sdk]
[ro.product.cpu.abi]: [armeabi-v7a]
[ro.product.cpu.abi2]: [armeabi]
[ro.product.manufacturer]: [unknown]
[ro.product.locale.language]: [zh]
[ro.product.locale.region]: [CN]
[ro.wifi.channels]: []
[ro.board.platform]: [rk29]
[ro.build.product]: [rk29sdk]
[ro.build.description]: [rk29sdk-eng 2.3.1 GINGERBREAD eng.zhansb.20111222.163508 test-keys]
[ro.build.fingerprint]: [rockchip/rk29sdk/rk29sdk:2.3.1/GINGERBREAD/eng.zhansb.20111222.163508:eng/opinions-on-teclast-p90hdst-keys]
[keyguard.no_require_sim]: [true]
[ro.com.android.dateformat]: [MM-dd-yyyy]
[ro.com.android.dataroaming]: [true]
[ro.ril.hsxpa]: [1]
[ro.ril.gprsclass]: [10]
[ro.config.notification_sound]: [OnTheHunt.ogg]
[ro.config.alarm_alert]: [Alarm_Classic.ogg]
[ro.opengles.version]: [131072]
[dalvik.vm.heapsize]: [48m]
[wifi.interface]: [wlan0]
[wifi.supplicant_scan_interval]: [15]
[persist.webview.minscale]: [0.5]
[persist.webview.maxscale]: [2]
[persist.webview.wml]: [disable]
[product.version]: [V1.03]
[EXTERNAL_STORAGE_STATE]: [removed]
[HOST_STORAGE_STATE]: [removed]
[persist.sys.timezone]: [Europe/Brussels]
[ro.sf.hwrotation]: [270]
[ro.tchip.defscr_timeout]: [30000]
[ro.tchip.defscr_br]: [225]
[ro.tchip.gpsShow]: [false]
[ro.lockScreen.batteryFlashShow]: [false]
[ro.tchip.OtgSoftSwitch]: [true]
[ro.tchip.3g]: [tdm330]
[ro.tether.denied]: [false]
[ro.tchip.hdmi_resolution]: [0]
[ro.tchip.recover_psw]: [false]
[ro.kernel.android.checkjni]: [1]
[ro.setupwizard.mode]: [OPTIONAL]
[dalvik.vm.dexopt-flags]: [m=y]
[net.bt.name]: [Android]
[net.change]: [net.dnschange]
[dalvik.vm.stack-trace-file]: [/data/anr/traces.txt]
[ro.tchip.version]: [(MC_CN@120215)_V2.1.12_36_TL12_PUBLIC]
[ro.tchip.factory]: [CUBE]
[ro.tchip.hdmi_scale]: [95]
[ro.tchip.homepage]: [http://www.51cube.com]
[persist.sys.localevar]: []
[persist.sys.language]: [fr]
[persist.sys.country]: [FR]
[ro.FOREGROUND_APP_ADJ]: [0]
[ro.VISIBLE_APP_ADJ]: [1]
[ro.PERCEPTIBLE_APP_ADJ]: [2]
[ro.HEAVY_WEIGHT_APP_ADJ]: [3]
[ro.SECONDARY_SERVER_ADJ]: [4]
[ro.BACKUP_APP_ADJ]: [5]
[ro.HOME_APP_ADJ]: [6]
[ro.HIDDEN_APP_MIN_ADJ]: [7]
[ro.EMPTY_APP_ADJ]: [15]
[ro.FOREGROUND_APP_MEM]: [2048]
[ro.VISIBLE_APP_MEM]: [3072]
[ro.PERCEPTIBLE_APP_MEM]: [4096]
[ro.HEAVY_WEIGHT_APP_MEM]: [4096]
[ro.SECONDARY_SERVER_MEM]: [6144]
[ro.BACKUP_APP_MEM]: [6144]
[ro.HOME_APP_MEM]: [6144]
[ro.HIDDEN_APP_MEM]: [7168]
[ro.EMPTY_APP_MEM]: [8192]
[net.tcp.buffersize.default]: [4096,87380,110208,4096,16384,110208]
[net.tcp.buffersize.wifi]: [4095,87380,110208,4096,16384,110208]
[net.tcp.buffersize.umts]: [4094,87380,110208,4096,16384,110208]
[net.tcp.buffersize.edge]: [4093,26280,35040,4096,16384,35040]
[net.tcp.buffersize.gprs]: [4092,8760,11680,4096,8760,11680]
[init.svc.servicemanager]: [running]
[init.svc.vold]: [running]
[init.svc.netd]: [running]
[init.svc.debuggerd]: [running]
[init.svc.rild-setup]: [stopped]
[init.svc.zygote]: [running]
[init.svc.media]: [running]
[init.svc.dbus]: [running]
[init.svc.installd]: [running]
[init.svc.flash_recovery]: [stopped]
[init.svc.keystore]: [running]
[init.svc.hdmi]: [stopped]
[init.svc.framework_config]: [stopped]
[init.svc.videosnapshot]: [running]
[init.svc.console]: [running]
[init.svc.adbd]: [running]
[init.svc.ril-daemon]: [running]
[init.svc.bootanim]: [stopped]
[hw.keyboards.0.devname]: [rk29-keypad]
[hw.keyboards.65537.devname]: [rk29-keypad]
[sys.event.capslock]: []
[sys.event.numlock]: []
[net.hostname]: [7d7448ee48212a41]
[dev.bootcomplete]: [1]
[sys.compatibility.mode]: [exit]
[gsm.version.ril-impl]: [android reference-ril V1.0]
[gsm.sim.operator.numeric]: []
[gsm.sim.operator.alpha]: []
[gsm.sim.operator.iso-country]: []
[gsm.sim.state]: [UNKNOWN]
[gsm.current.phone-type]: [1]
[gsm.operator.alpha]: []
[gsm.operator.numeric]: []
[gsm.operator.iso-country]: []
[gsm.operator.isroaming]: [false]
[sys.boot_completed]: [1]
[init.svc.watchdog]: [stopped]
[wlan.driver.status]: [ok]
[init.svc.wpa_supplicant]: [running]
[ro.runtime.firstboot]: [1388768347843]
[wpa_supplicant.interface]: [ready]
[net.dnschange]: [2]
[dhcp.wlan0.result]: [ok]
[init.svc.dhcpcd]: [running]
[dhcp.wlan0.pid]: [339]
[dhcp.wlan0.reason]: [BOUND]
[dhcp.wlan0.dns1]: [192.168.1.1]
[dhcp.wlan0.dns2]: []
[dhcp.wlan0.dns3]: []
[dhcp.wlan0.dns4]: []
[dhcp.wlan0.ipaddress]: [192.168.1.11]
[dhcp.wlan0.gateway]: [192.168.1.1]
[dhcp.wlan0.mask]: [255.255.255.0]
[dhcp.wlan0.leasetime]: [86400]
[dhcp.wlan0.server]: [192.168.1.1]
[net.dns1]: [192.168.1.1]
======================= SYSTEM LOG ===================
======================= RADIO LOG ===================
======================= KERNEL LOG ===================
======================= RUNNING PROCESSES ===================
USER PID PPID VSIZE RSS WCHAN PC NAME
root 1 0 296 200 c05b84c8 0000e06c S /init
root 2 0 0 0 c055f32c 00000000 S kthreadd
root 3 2 0 0 c054fe4c 00000000 S ksoftirqd/0
root 4 2 0 0 c057e7c8 00000000 S watchdog/0
root 5 2 0 0 c055bc68 00000000 S events/0
root 6 2 0 0 c055bc68 00000000 S khelper
root 7 2 0 0 c0565764 00000000 S async/mgr
root 8 2 0 0 c055bc68 00000000 S suspend
root 9 2 0 0 c0595360 00000000 S sync_supers
root 10 2 0 0 c0595bb8 00000000 S bdi-default
root 11 2 0 0 c055bc68 00000000 S kblockd/0
root 12 2 0 0 c055bc68 00000000 S ksuspend_usbd
root 13 2 0 0 c07a5858 00000000 S khubd
root 14 2 0 0 c055bc68 00000000 S kmmcd
root 15 2 0 0 c055bc68 00000000 S kondemand/0
root 16 2 0 0 c055bc68 00000000 S rk29_cpufreqd
root 17 2 0 0 c057ea00 00000000 S khungtaskd
root 18 2 0 0 c0590384 00000000 S kswapd0
root 19 2 0 0 c055bc68 00000000 S aio/0
root 20 2 0 0 c055bc68 00000000 S crypto/0
root 30 2 0 0 c06d83d8 00000000 S mtdblockd
root 37 2 0 0 c07cbcdc 00000000 S usb_mass_storag
root 38 2 0 0 c055bc68 00000000 S rk2918_battery/
root 39 2 0 0 c055bc68 00000000 S kstriped
root 40 2 0 0 c055bc68 00000000 S kconservative/0
root 41 2 0 0 c055bc68 00000000 S usbhid_resumer
root 42 2 0 0 c055bc68 00000000 S binder
root 43 2 0 0 c0563fd4 00000000 S galcore daemon
root 44 2 0 0 c055bc68 00000000 S camera wq/0
root 49 2 0 0 c055bc68 00000000 S goodix_wq/0
root 50 1 264 160 c05b84c8 0000e06c S /sbin/ueventd
root 51 2 0 0 c055493c 00000000 S rknand_buffer
root 54 2 0 0 c05c7d84 00000000 S flush-31:0
root 55 2 0 0 c062dde8 00000000 S kjournald
root 57 2 0 0 c062dde8 00000000 S kjournald
root 59 2 0 0 c062dde8 00000000 S kjournald
system 60 1 800 288 c082971c afd117bc S /system/bin/servicemanager
root 61 1 3908 464 ffffffff afd11e6c S /system/bin/vold
root 62 1 4284 596 ffffffff afd11e6c S /system/bin/netd
root 63 1 664 240 c0867d9c afd1218c S /system/bin/debuggerd
root 65 1 105956 19180 c05b84c8 afd11904 S zygote
media 66 1 38268 2064 ffffffff afd117bc S /system/bin/mediaserver
bluetooth 67 1 1252 368 c05b84c8 afd1265c S /system/bin/dbus-daemon
root 68 1 800 316 c08fa578 afd1151c S /system/bin/installd
keystore 70 1 1784 344 c0867d9c afd1218c S /system/bin/keystore
root 73 1 16520 1472 ffffffff afd117bc S /system/bin/videosnapshot
root 74 1 2016 48 c06a1df0 00008e3c S /system/bin/busybox
root 75 1 3372 176 ffffffff 0000f8e4 S /sbin/adbd
root 83 1 4416 528 ffffffff afd11e6c S /system/bin/rild
system 94 65 323484 36224 ffffffff afd117bc S system_server
system 156 65 164252 25368 ffffffff afd125dc S com.android.systemui
app_15 165 65 139748 21788 ffffffff afd125dc S com.fiberthemax.OpQ2keyboard
radio 171 65 127836 20212 ffffffff afd125dc S com.android.phone
app_20 209 65 157868 22420 ffffffff afd125dc S com.google.process.gapps
root 276 1 2208 628 c05b84c8 afd11904 S /system/bin/wpa_supplicant
app_22 281 65 120084 19528 ffffffff afd125dc S android.process.media
root 304 2 0 0 c0563fd4 00000000 S RTKTHREAD
dhcp 339 1 840 332 c05b84c8 afd1265c S /system/bin/dhcpcd
system 347 94 317892 30048 c056cb48 afd127f8 S system_server
app_20 407 65 282820 22552 ffffffff afd125dc S com.google.android.gms
app_16 440 65 225764 39492 ffffffff afd125dc S com.android.vending
app_57 472 65 123808 21328 ffffffff afd125dc S com.noshufou.android.su
app_9 498 65 313496 93700 ffffffff afd125dc S mobi.mgeek.TunnyBrowser
app_24 508 65 197252 25444 ffffffff afd125dc S net.suckga.iLauncher2
app_60 520 65 123416 22852 ffffffff afd125dc S cm.aptoide.pt
app_5 634 65 115340 17284 ffffffff afd125dc S com.android.defcontainer
app_12 644 65 115332 16968 ffffffff afd125dc S com.svox.pico
app_1 655 65 116552 18208 ffffffff afd125dc S com.android.quicksearchbox
app_31 718 65 123716 19324 ffffffff afd125dc S com.google.android.googlequicksearchbox
app_25 735 65 127012 22180 ffffffff afd125dc S t0mm13b.dmesglog
app_21 823 65 124048 19256 ffffffff afd125dc S com.google.android.voicesearch
app_9 856 498 672 252 c0563620 afd11e6c S /data/data/mobi.mgeek.TunnyBrowser/files/watch_server
app_55 884 65 118044 21352 ffffffff afd125dc S com.android.packageinstaller
app_26 900 65 215388 32580 ffffffff afd125dc S com.GetLogs
app_7 958 65 137260 32928 ffffffff afd125dc S com.speedsoftware.rootexplorer
app_7 967 958 740 372 c054db54 afd1246c S /system/bin/sh
root 994 967 740 372 c05b1304 afd1151c S sh
root 1023 900 740 368 c054db54 afd1246c S sh
root 1033 1023 924 360 00000000 afd1151c R ps
Open a terminal and type:
su
dmesg >/mnt/sdcard/dmesg.txt
Zip and upload the log as attachment.
Cube U10GT2 8" 1024*768 (4:3), Goodix_TS, RTL8188 WLAN on USB11, MMA7660 Sensor, WM8900 Audio, OV7675 fcam, OV2655 rcam, ANX7150 HDMI, HYM8563 clock, GSM modem
Could be an U10GT with GSM modem. Kernel for U10GT is in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1353
You should have the old firmware as fall-back.
Build is here: http://forum.xda-developers.com/showthread.php?t=1903745
Change your kernel in folder rockdev/Image.
58 Guest(s)
Devices in use: Desktop (48), Phone (10)
cutierogue
