2013/10/17
Hello, I´m looking for update the odys xpress.
I just update with "Oma_Odys_Loox_JB_4.1.1_v1.3a" i found here and the install is ok, but when the tablet boot the first time, i can´t control the CWW with the volumen +- bottom and the touch screen doesn´t work so i can´t install the "Oma JB v1.3 Format NAND" , i can only reboot the tablet with the power bottom.
When the tablet is on, seem to boot ok, but the touch screen doesn´t work and some error are display in the screen like if some modules can´t start.
After that if i reinstall the original rom, all is ok, but with the old android ofcourse
What i´m doing bad? maybe this room doesn´t work with xpress? only for loox?
I´ll try to update the tablet from a Win-7 and Win-xp too (well ok, win-media center ) with the same results
Help please!!
2013/10/17
ok ok, i read and now I know that I have to install special kernel. I used kernel_308_xpress_44 and a fix for this tab Oma_JB_v1.2_Modell_fix_Xpress.
so, now my tablet has:
Are this files correct for this tab? I saw a fix with 1.3 for "loox" and "xpress pro (Oma_JB_v1.2_Modell_fix_Xpress Pro.zip)" but I don´t know if i can use these files or if this is correct for me.
well, is ok? can I use de 1.2 fix for the 1.3a Crom? or if any other Crom better than this one for me?
Thanks for your reply
Pls use the v1.2.4 build: http://crewrktablets.arctablet.com/?wpfb_dl=639
Latest kernel is #46: http://crewrktablets.arctablet.com/?wpfb_dl=372
Model fix: http://crewrktablets.arctablet.com/?wpfb_dl=223
burnkeysPer aspera ad astra, we rock the Tablets !
2013/10/17
Thank you for your reply
so, I suppose that I have to use "Oma JB v1.2 Format NAND" that´s right?
Thanks again for your great work
Burnkeys
P.d: I don´t know why, but when I installed "the v1.2.4 build" with the "latest kernel 46", I can´t use the touch screen to install the "model fix" and the volumen bottom +/- don´t work. Any suggestion? Thanks
P.d2: Ok, I solved updating the tab with the recovery.img I founded in "Oma_Odys_Loox_JB_4.1.1_v1.3a". So now my tab is update with:
-Oma_Odys_Loox_JB_4.1.1_v1.2.4a
-kernel_308_xpress_46
-recovery.img file from "Oma_Odys_Loox_JB_4.1.1_v1.3a" (could be... cww 6.0.28 or something like that )
-Oma JB v1.2 Format NAND
-Oma_JB_v1.2_Modell_fix_Xpress
I hope to be in the correct way. Now, Time to Test!!
56 Guest(s)
Devices in use: Desktop (48), Phone (8)
