Kernel für Odys NEO X8, NEO X7, BQ-Kepler2, BQ-Pascal2, Arnova AN8CG3, M820c3G, Hyundai H900
Sjemen
2014/03/09 - 21:43
On this thinks that used the kernel JK_JB308_hyundai-h900_oc1104_20121214 firmware version Oma_Odys_Loox_JB_4.1.1_v1.3a and fix CrewRKTablets_AOSP_4.2.2_Format_nand_fix + Oma_intSD_to_NAND_OTG_fix + Oma_JB_v1.3_Modell_fix_Odys Loox . There is no sound ; incorrect display of the battery ; the files are attached as-is un zip
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/03/10 - 16:56
we don't need the executable files, we need the output of them.
In Terminal Emulator enter
su
dmesg > /mnt/external_sd/dmesg.txt
Sjemen
2014/03/10 - 18:26
I'm sorry , but I don't really understand what the emulator , I don't have it ??? Maybe another way to do it ?
2014/03/10 - 18:57
Just load it from Play Store: https://play.google.com/store/apps/details?id=jackpal.androidterm
Sjemen
2014/03/10 - 19:24
Well turned out , the file as-is
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/03/10 - 19:58
ok,
First, why did you use this old Kernel and not the younger one mentioned in first post?
JK-kernel_308_hyundai-h900_201301121601_JB.7z
Second, why did you use such an old rom and not the CM10.1 Build with the correspondig H900 Kernel?
Sjemen
2014/03/10 - 20:25
I apologize for the incorrect data ... Other options are not loaded , hangs on the splash screen , the kernel does not fit , a dark screen..... Here is the last sample
firmware Oma_Odys_Loox_JB_4.1.1_v1.2.4a
fix CrewRKTablets_AOSP_4.2.2_Format_NAND_Fix
Variant with  CM10.1 does not boot , or hanging touch , or a dark screen .....It is the best variant of Assembly , here is the sound of return and well .....
2014/03/10 - 20:52
When you mix up all these things the build will surely crash.
Build is here: http://crewrktablets.arctablet.com/?p=1873
Kernel is here: http://crewrktablets.arctablet.com/?wpfb_dl=1386
Just use the format_NAND. No other fix.
btw: your tab is a H900 ?
Sjemen
2014/03/10 - 21:01
Yes , Hyundai H900 , just the other original inscriptions no ....
Sjemen
2014/03/10 - 21:34
Not gone , black screen and all , and CWM not opened ,I tried this option , was hung on the splash screen
2014/03/10 - 21:48
Try again and do a clean install incl eraseIDB.
Sjemen
2014/03/10 - 21:56
I always do eraseIDB , with kernel crewrktablets_kernel_308_hyundai-h900_201401121843_JB422 no firmware does not start ....
Sjemen
2014/03/11 - 21:35
I understand not help to solve the problem .....FrownFrownFrownCry
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/03/16 - 16:40
It is not easy to help, without having the tablet.
Please describe exactly each step and every zip you install.
Sjemen
2014/05/14 - 19:12
Good time of day . I don't what to clarify . The file in the kernel folder rockdev/image , run RKAndroidTool included EraseIDB , then start (run) . After restart run CWM , start format_NAND.zip and restart and start tablet . Get the screensaver crewrktablets and that's all , a long stop . And there is a possibility to get the original firmware from Hyundai H900 ?
Currently Online: vishu bhatnagar
49 Guest(s)
Devices in use: Desktop (48), Phone (2)
vishu bhatnagar
djwood1014
4ipolino
thomashansmuller11
abro
Yoyoo
