2013/11/20
Hello. I need help with installing CM10.1 for my BQ Pascal B23. Now I'm using jellybean. Here is fixes what I use:
Oma JB v1.2 Format NAND.zip
Oma_intSD_to_NAND_fix.zip
Oma_JB_v1.2_Modell_fix_Pascal.zip
Oma_JB_v1.2_akkufix_2.zip
Kernel:
kernel_308_pascal_b23_bq.7z
What fixes I must use for CM10.1?
llort_trollPer aspera ad astra, we rock the Tablets !
Boot-loop into recovery? Did you execute eraseIDB?
Ok, fine. Install format_NAND fix and reboot.
Test and give feedback of what is not ok.
Ok, install the battery info fix.
Try sensor fix 1-4.
Just follow the link in post #2.
Could be. The build is done for a wide range of screens. Ignore or maybe use an other launcher.
67 Guest(s)
Devices in use: Desktop (62), Phone (5)
revoltown
tdomnic024
otismaibe
Tsuna77
docentik2006
