2013/02/28
Hi, please help me and my poooor tablet. I've a Mediacom 810c (cex model) tablet with rk29 chip, my usb input is broke and I can't flash from RkTool. Now the tablet mount android 4.0 but i wolud to flash new cm rom.
Please give me a clean backup, without accounts and app, please. :'(
2012/11/19
I'm sorry, but I think that this would not work.
Every Rom has a specific partition table in the flash. Even if you would try to play back a cwm CM10.1 backup from us, it would not fit to the partitions you have in your flash.
mattiaPer aspera ad astra, we rock the Tablets !
2013/02/28
mmm I have installed a custom rom and I have already done this once and I did not have problems, maybe it was a case..
However i would try this, I have a backup of my actual rom...my last hope is to operate with hardware... replace broken part..
Is there any way to flash without USB? I think no but I'm not sure..
2012/11/19
You have CWM installed right? What custom rom do you use?
2012/11/19
You can try it, but be aware it could brick your tablet.
Tonight I will flash a Odys NEO X8 with CM10.1 for testing purpose. I will make a nandroid backup and give you a link to it.
2012/11/19
you shoud have a mail from crewrktablets with a gdrive link to a clean nandroid backup.
Perhaps it works for you, please keep us informed.
Regards
JochenKauz
2013/02/28
Thanks to everyone but at the end I brick my tablet.
I asked to another user a copy of his backup without any personal file or data so he sent me a copy without /system folder.
Recovery mode give an error if you try to restore a backup without all files that you are saved (mismatch of .md5 file) so I think to modify .md5 file and ok, I removed the string of md5 system from the file.
It gave me an error so I tried to restore part by part with "advanced restore", but when I'm arrived to restore the kernel the tablet went to bootloader mode. Now I must replace usb input and I restore the tablet from pc.
-_-
However like JochenKauz said, now I have serious doubts about this operation... If you have another partition table different from the Rom that you will flash it was impossible...
(Sorry if my english is bad)
2012/11/19
Sad to hear that you brick your tablet.
Hopefully you get the USB fixed, cause CM10.1 is great on the rk2918.
72 Guest(s)
Devices in use: Desktop (67), Phone (5)
hans41
rickybk
soniya07
ironmangitar
