Crew RKTablets Loox CM10.1 v1.2 Screen Rotation not Working.
jjcool
2013/10/03 - 22:52
Hello Oma,
I rebooted the tablet in recovery and rerun de format nand script.
after reboot still no rotation.
settings -> display -> rotation -> auto-rotate screen is enabled and the 0,90,180,270 rotation modes to.
rerun my fixscript with the 90 degree failure and run androsensors and give me this result:
- tab vertical, landscape x = +9.5 m / s2
- turn left to portrait y = -9.8 m / s2
- turn right to portrait x = +9.8 m / s2
- tab horizontal screen up z = +9.6 m / s2
rerun your http://crewrktablets.arctablet.com/?wpfb_dl=976
androsensors result is
- tab vertical, landscape y = + 9745.4894 m / s2
- turn left to portrait x = + 9768.2837 m / s2
- turn right to portrait x = - 9854.7485 m / s2
- tab horizontal screen up z = + 9270.5134 m / s2
Now i see that i misinterpreted the numbers.
my apologies Oma
greeting jjcool
netlars
Forum Posts: 149
Thanks Received: 29
2013/10/04 - 08:52
The following users say thank you to netlars for this useful post:
leoseccia, admin, jjcool, spupi
jjcool
2013/10/04 - 20:38
Hello Netlars and Oma,
This one did the trick, rotation works super Laugh
Thanks for your time and nice work.
Greetings JJcool
2013/10/08 - 19:37
Guys, everybody fine with rotation? Give feedback on different tabs, so other user can participate.
2013/10/08 - 19:52
I'll check and post feedback for the Arnova 10b G3 soon.
spupi
2013/10/09 - 17:24
everything perfect on Arnova 9g2.
2013/10/09 - 19:35
Tested Crew RKTablets Loox CM10.1 v1.2.1 on the Arnova 10b G3, the accelerometer wasn't right with the default sensor lib from the firmware but the problem got fixed with  http://crewrktablets.arctablet.com/?wpfb_dl=976 (CrewRKTablets_CM10.1_sensor_X=Y_Y=-X_Z=Z.zip)
I'll later upload that custom firmware for the Arnova 10b G3.
jumangi
2013/10/10 - 13:43
Hi all, flashed on Arnova 7f G3  patched with
CrewRKTablets_CM10.1_Format_NAND_Fix
CrewRKTablets_CM10.1_TabletUI_fix
 everything and rotation work fine remain the battery percentage indicator problem but that's another story.
Great work! Thanks a lot to everybody.
The following users say thank you to jumangi for this useful post:
jjcool
2013/10/12 - 23:01
Hallo all
I want to share with you ​​this fix . it fix the wiffi and the rotation on the
TomTec Ultimate 10 ATP7659 with prodnum 273. after you installed the Crew RKTablets Loox CM10.1 v1.2.
greetings JJcool
The following users say thank you to jjcool for this useful post:
masternetpro
2013/10/21 - 09:03
I have Yan Tablet 8.1g , i flash CrewRKTablets_RK29_Loox_CM10.1_4.2.2_v1.2.1 everything good, but camera and rotation run not true..it disorder..and touchscreen not working.
Pls help me about it.tks
2013/10/21 - 09:21
Is the stock firmware available?
masternetpro
2013/10/21 - 10:33
do you have stock firmware for yan tablet 8.1g?
First, my tab run firmware 4.0.3 is normal. (now i don't have stock firmware) Last i run your rom "CrewRKTablets_RK29_Loox_CM10.1_4.2.2_v1.2.1" , everything is good. Now i use it..But camera and rotation run not true..it disorder..and touchscreen not working.
I ran stock firmware yan tablet 8.1 but it don't still work..Website stock here í shared.
 U can help me fix it...
2013/10/21 - 10:38
Do not flash anything into the tab without having a fallback.
We need the genuine kernel for the tab, that's why we need the stock firmware or a dump of it.
masternetpro
2013/10/21 - 11:29
Ok, is this Vietnames? Hope you mean this: https://app.box.com/s/c6b3c6ad389cbc88fd5e/1/268804645
Very interesting build ;-)
ro.build.display.id=TOMTEC-eng 4.0.3 IML74K eng.root.20120306.193250 test-keys
ro.product.model=Yan 8.1
ro.product.brand=TOMTEC
Kernel is here: http://crewrktablets.arctablet.com/?wpfb_dl=1027
Change in folder rockdev/Image
masternetpro
2013/10/22 - 05:19
I run this kernel http://crewrktablets.arctablet.com/?wpfb_dl=1027 ,but everything don't still change. camera and rotation run not true..it disorder..and touchscreen not working.
This link that i gave you ,i ran it but not working about problems i say. Thanks.
My tab is Yan Tablet 8.1G not TOMTEC.
71 Guest(s)
Devices in use: Desktop (64), Phone (7)
