Try this: http://crewrktablets.arctablet.com/?wpfb_dl=911
jjcoolPer aspera ad astra, we rock the Tablets !
2012/11/19
Both problems are known for stock kernels.
For the Rotation we were able to build an own sensor lib... Problem, we must know how to rotate, so we would need your help to get it working.
The battery is another problem, stock kernels are using a specialised mode for charging that is not recognized by android in standard config. We try to fix it, but not easy to implement,
ghostbar, adriannarn, rmmsPer aspera ad astra, we rock the Tablets !
2013/08/28
I have installed this on my old Arnova 9g2 and screen rotation was not working at all.
I have then updated with Oma_JB_v1.2_Modell_fix_Arnova 9G2 and now the sensor work but it is 90 degrees (clockwise) off. I tried CrewRKTablets_CM10.1_Sensor_90_Degree_Fix but that breaks it again.
Any ideas?
Thanks for this brilliant ROM - it's awesome!
Leo
2013/08/05
Hello Crew RKTablets,
My TomTec Ultimate 10 ATP7659 with prodnum 273.
Is installed with Crew RKTablets Loox CM10.1 v1.2.
After installation wifi and rotation not working.
- Wifi freezes when switching wifi on.
- Rotation is on but does not function.
After research I made ​​this fix from the tomtec stock 4.1 rom.
After the fix wifi works perfectly and the rotation works only 90 degrees backwards
Can you fix this.
ThanksÂ
Fine.
Flash this fix: http://crewrktablets.arctablet.com/?wpfb_dl=972
Load Androsensor from Play-Store and post axis with highest value (9.x) for:
- tab vertical, landscape (y=9.8)
- turn left to portrait (x=9.8)
- turn right to portrait (x=-9.8)
- tab horizontal screen up (z=9.8)
Orientation & Rotation right now?
Could not be. Androsensor show an event. Did you disable rotation everywhere?
106 Guest(s)
Devices in use: Desktop (95), Phone (11)
matinf
floki
orocamora
Ellocojoe
Tonysc17
olegator
