2015/01/17
I use a Technaxx TechTab (rk29board).
I installed Crew RKTablets Loox CM10.1 v1.2 rom and it runs fine.
Unfortunately, the battery has the cm10.1 installation after a short time (about 1 hour) empty.
The display on the battery consumption is to recognize that Wi-Fi is always active (not standby even though the display turns off) and mobile data consume energy even though the TechTab has no 3G module.
Is there a solution to this problem?
You can set keep wi-fi on during sleep to never.
Mobile data can only consum battery when the hardware is there. Android stats are missleading in that case.
Also take into account that the battery is simply old. My Tab is now 3 years old and the battery is completly done.
MatzelBPer aspera ad astra, we rock the Tablets !
2015/01/17
I have my "TechTab" checked.
keep wi-fi on during sleep = never.
But Wi-Fi turned not off automatically when Tab sleep.
I think the battery is fine. I install "Forgotten Tabs Project v1.2.4 JB", the battery runs for many hours. If Tab sleep Wi-Fi turned off automatically.
- MatzelB -
Fine. Thank you for feedback!
2016/01/21
Hi, I realize this thread is somewhat old, but it's the only TechTab-specific one I found. I want to install Crew's JB on mine, but after reading this, the last five pages of Loox/ICS on android-hilfe and browsing the CrewRK site, I'm still confused which file to download and use. I understand there are roms and device-specific fixes, so ... the way I understand it, I'll download CrewRKTablets_RK29_Loox_JB_4.2.2_windoof_v1.0.7z, see how it's doing, and if there are errors, I'll use Oma_JB_v1.2_Modell_fix_Technaxx TechTab.zip to patch it up?
Thanks in advance for any help. And thanks a lot for your work, I see you're starting on Ubuntu tablet now, which is also great! I'm really looking forward to making real use of my old tablet that has been dusting away in a corner for the last few years.
Cheers
77 Guest(s)
Devices in use: Desktop (69), Phone (7), Tablet (1)
jenom
kfwacky
fer30
culo1
dfrt
PQNY
