2013/12/09
I've installed CM10.1(Odys Loox cRom v1.2.3) in my BQ-Tesla. After trying the four patches proposed for fix the sensor, I can't auto-rotate my screen. Three of them fail at all, although one of them allows autorotate the screen, but in a wrong direction. If I turn right 90 degrees my table to the right, it rotates 90 degrees the screen in a bad direction, that is, 90 degrees to the right, leaving the image 180 degrees inverted. What I would need to rotate the image -90 degrees (to the left) or 270 degrees (to the right).
The fix that allows rotation is that one called:
 CrewRKTablets_CM10.1_sensor_X=Y_Y=-X_Z=Z_sensitivity_1000000.zipÂ
I believe the other patches don't work because of de sensitivity. I guess I need, at least, 1000000 of sensitiity.
Could anyone help me building a new "sensors.rk29board.so" in order to rotate the image -90 degrees (to the left) or 270 degrees (to the right) with a sensitivity of at least 1000000?
I've tried with "ro.sf.hwrotation=90" o "ro.sf.hwrotation=270" (in build.prop file) without lucky since then, what I see on my screen is not there but it is in other area of the screen. It is like you see the content in a rotate way from what you choose when you push on the screen.
Please, can you help me? This is the only issue with this tablet that I don't be able to solve.Â
Leaving this issue at side, this ROM works great in BQ-Tesla.
Thanks in advance.
ferran.sabatePer aspera ad astra, we rock the Tablets !
2013/12/09
Can you pls test: http://crewrktablets.arctablet.com/?wpfb_dl=1271 Â - Oma - Â
Oma, thanks for your quick answer.
I've tested your new option and what happens now is that when I put the tablet in landscape mode the screen rotates to portrait mode; and when I put the Tablet in portrait mode, the screen change to landscape mode. In both cases and assuming you have switched off the auto-rotation option, you have to rotate the tablet 90 degrees to the right in order to view the screen in the correct position.
I hope my explanation could be enough clear, if not I'll attach some images...
Thanks a lot for your amazing work.
Load Androsensor from Play-Store and post axis with highest value (example) for:
- tab vertical, landscape (y=+9.8)
- turn left to portrait (x=+9.8)
- turn right to portrait (x=-9.8)
- tab horizontal screen up (z=+9.8)
2013/12/09
Load Androsensor from Play-Store and post axis with highest value (example) for:- tab vertical, landscape (y=+9.8)
Ok, these are my values (I've installed the option you give me in post #2):
#1 tab vertical, landscape (x=-9.8; y~0; z~0; Sigma=+9.8)Â
#2 turn left to portrait (x~0; y=+9.6; z~0; Sigma=+9.6)
#3 turn right to portrait (x~0; y=-9.6; z~0; Sigma=+9.6) (turn right from #1 position)
#4 tab horizontal screen up (x~0; y~0; z~=+9.6; Sigma=+9.6)
Thanks again,
FSG
2013/12/09
Oma7144 saidÂ
Pls try again: http://crewrktablets.arctablet.com/?wpfb_dl=1272
Hi Oma,
I'm sorry but it doesn't work well. The screen is 180 degrees to the left or to the right; that is, in portrait mode you see the screen in portrait but 180 degrees rotated and in landcape mode you see the screen in lanscape but 180 degrees rotated.
It seems like you have proposed me the same solution that I had in first time, that is:
http://crewrktablets.arctablet.com/?wpfb_dl=978Â (CrewRKTablets CM10.1 Sensor X=Y Y=-X Z=Z Sensitivity 1000000 (236.5 KiB); this is the last link in the Downloads webpage (http://crewrktablets.arctablet.com/?page_id=208)
In order to help you I've attached two screenshots:
I hope the next try could be the good one, I afraid I'm disturbing you too much.
Thanks again,
FSG
2013/12/09
- Oma -Ok, these are my values (I've installed the option you give me in post #2):
#4 tab horizontal screen up (x~0; y~0; z~=+9.6; Sigma=+9.6)Thanks again,
FSG
Hi Oma,
It seems like I made a mistake when I answer the axis values. These are the correct ones, at least, after installing the last solution you gave me (Â http://crewrktablets.arctablet.com/?wpfb_dl=1272)Â
#1 tab vertical, landscape (x=0; y=-9.8; z~0; Sigma=+9.8)Â
#2 turn left to portrait (x=-9.6; y~0; z~0; Sigma=+9.6)
#3 turn right to portrait (x=+9.6; y~0; z~0; Sigma=+9.6) (turn right from #1 position)
I'm so sorry for my mistake.
Thanks,
FSG
Hm, finished this one already ... pls test: http://crewrktablets.arctablet.com/?wpfb_dl=1275
2013/12/09
Hm, finished this one already ... pls test: http://crewrktablets.arctablet.com/?wpfb_dl=1275 Â - Oma -Â
Hi Oma,
Perfect! Now auto-rotation is working properly... THANKS A LOT!Â
Let me ask you a last and easy question: is the fix for CRT Effect working well with CM10.1 (Odys Loox cRom v1.2.3) version?
Again, thank you very much!
FSG
Yes.
84 Guest(s)
Devices in use: Desktop (72), Phone (12)
ahurtama
DEric
dderwin
fantom0308
Morris028
robertgdfdgdfss
