2014/01/27
I have a nextbook Next 8p12SE-HD with the CM10.1 v1.2.4 and the new kernel but the camera its mirroed. Any solutions for that? thanks in advance
2012/11/19
yes I can flip camera, but I need your help for that. Please make a photo of the mirrored picture and a photo of a correct one. I have to look how I must mirror the cam, is it a only mirror, is it a flip (x/y) or is it a combination of both. Then I can make a custom kernel that rotates the camera in the right direction.
andre_amaralPer aspera ad astra, we rock the Tablets !
2014/01/27
JochenKauz said
Hi,yes I can flip camera, but I need your help for that. Please make a photo of the mirrored picture and a photo of a correct one. I have to look how I must mirror the cam, is it a only mirror, is it a flip (x/y) or is it a combination of both. Then I can make a custom kernel that rotates the camera in the right direction.
I take the pictures and there they are. I have a problem with HDMI too. It doesn't work. When a conect to the TV the image on the tablet goes black but nothing happens on the tv.
I will send to you the kernel to.
Thank you.
The first one is the photo taken with my tablet and the second one is how the image suposed to be.
2012/11/19
okay, the camera is not mirrored, it's a wrong rotation, it should be 270 degrees clockwise. I will try to fix it.
HDMI is another point, did you ever booted the device with hdmi attached?
For me HDMI is working fine, but I have to switch the tablet off, connect it to TV and then switch it on.
Thanks for the kernel, but it is a kernel I have made, so I have it on my hdd.
Cause I'm busy with Kitkat at the moment, the new kernel will need a few days.
Regards
JochenKauz
2014/01/27
JochenKauz said
Hi,okay, the camera is not mirrored, it's a wrong rotation, it should be 270 degrees clockwise. I will try to fix it.
Regards
JochenKauz
Yes i already did that, reboot the tablet with the HDMI connected and the same happened.Â
I will wait for the kernel, its nothing that important. But KitKat on RK2918 devices that will be something important, I hope that will happen.Â
RegardsÂ
2012/11/19
we are working hard on that..
2012/11/19
I'm sorry not yet. I was to busy with other things.
I'll try it in the next days.
Really sorry for that.
JochenKauz
2012/11/19
Still no time, too much work in real life.
But you are the next on my list.
2012/11/19
Okay, one thing I need.
I use a Multi Cam driver in the kernel, do you know what cam is buildin, or do you can provide a dmesg for me?
2012/11/19
ok gc0308, I will see what I can do.
Currently Online: portvein
80 Guest(s)
Devices in use: Desktop (67), Phone (14)
montolla
portvein
POELE
hststs44
lokeshreddymtpl
scoopsat
