2013/11/07
Hi All,
I had some problems with the "Newest CM 10.1/AOSP 4.2.2 Homebrew Kernel for RK2918 based Tablets".
Friday january 17, on my Arnova 9G2 I tried the following:
ROM CrewRKTablets_RK29_AOSP_4.2.2_r1_v1.3_20130714
Kernel kernel_308_arnova-an9g2_201401121843_JB422
Kernel kernel_308_arnova-an9g2_201312311046_JB422
In both cases the tablet started in blank status and Windows Device Manager says to me that it found a "Nexus".
After these not successfull tests I installed the following:
Kernel kernel_308_9g2_arnova
In this case the Tablet started but CWM was not the touch version so I could not apply fixes (format_nand etc.).
Saturday January 18, I tried the following:
ROM CrewRKTablets_RK29_Loox_CM10.1_4.2.2_v1.2.4
In both cases the tablet started in blank status and Windows Device Manager says to me that it found a "Pascal2".
In this case the Tablet started, CWM was the touch version so I applied fixes (format_nand etc.).
The problem is that the Loox version of the rom is plenty of sw I don't really need (Nova e Trebuchet) and it gives me the sensation is particularly heavy for the low HW dotation of this Tablet.
Do you think it's possible to have a good AOSP with the correct CWM and a overclocked processor homebrew kernel for the Arnova 9G2?
Thank you in every way for the nice job you do for the community!!!
Tore
2012/11/19
Trebuchet is the stock launcher of CM, and because many people like the Nova launcher, both are there in the ROM.
If you need a Touch CWM, you can download this http://crewrktablets.arctablet.com/?wpfb_dl=464. Simply replace the recover.img in rockdev/image folder.
What do you mean with blank status, did you see kernel logo and then it did not enter CWM?
TorePer aspera ad astra, we rock the Tablets !
2012/11/19
Okay, then there is a problem with the screen driver I think.
I don't know if I can fix it.
58 Guest(s)
Devices in use: Desktop (50), Phone (8)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
