Archos Carbon 97 running ASOP 4.2.2 v.1.3
90 Degree Sensor Fix
surgeman
Forum Posts: 19
2014/04/23 - 21:31
Ok good deal...Thanks for all your help Oma..To anyone else viewing this thread.If you have a Archos Carbon 97 this is a must have ROM for it.Very smooth and works very well.Keep the great work up OMA....
surgeman
Forum Posts: 19
2014/04/26 - 23:41
I was writing again about the kernel file to enable usb debugging..That kernel doesn't work...I have tried it on a clean install..and it won't connect...Mass storage works great...but no USB debugging at all...Thanks..
ian
United Kingdom
Forum Posts: 30
2014/07/24 - 09:38
I am running this on an Arnova 9 G3 - and am very impressed, thank you for the hard work.
However I have seemed have lost write access to my SD card via USB (Mass Storage).  I am not too worried as I can pop the SD card out and write directly to it.
2014/07/24 - 15:57
Did you install the PhabletUI ?
ian
United Kingdom
Forum Posts: 30
2014/07/25 - 09:25
No I have only installed CrewRKTablets RK29 AOSP 4.2.2 R1 v1.3 20130714 so far.  Should I install the TabletUI/PhabletUI?  I am guessing that if I need either one it is personal choice?
2014/07/25 - 17:03
Ah, ok .. you are running one of the old testbuilds.
Check out the CM10.1 build: http://crewrktablets.arctablet.com/?p=1873
95 Guest(s)
Devices in use: Desktop (85), Phone (10)
Ellocojoe
Tonysc17
olegator
Ur
beelink
TheMentor
