Fine. Which patch? What is the start-up orientation?
Hm, when there is contact to the sensor you should have rotation.
2014/04/21
It shows in the graph bar that the sensors are monitoring.But when you rotate the tablet it stays in landscape mode at all times.It works fine with the stock firmware.I never use portrait mode anyway but I was trying to patch it if possible.I can force it with Real Calculator to portrait mode if I need to use it and force it back with any game just about.
Could be trough the strange fix CM10 fix.
Install this rotation app via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=1369
Can you pls test: http://crewrktablets.arctablet.com/?wpfb_dl=1712
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=1712
surgemanPer aspera ad astra, we rock the Tablets !
Fine. For other user to participate, here is the kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1713
Set storage to MTP and then USB-debugging.
62 Guest(s)
Devices in use: Desktop (56), Phone (6)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
