2012/11/19
To compile a kernel you do not need -i.
All that have to be done:
1. Setup the correct toolchain and switch to it.
2. then a "make whatever_defconfig" you need, e.g "make odys-neox8_defconfig"
3. perhaps a make menuconfig to change configuration
4. last step depending on the processor you use, a e.g. make -j4 kernel.img
But(!) if you configure different hardware drivers to our normal defconfigs, be aware that there could be parameters/structs etc. that not match. So if this happens you have to change board-xxx.c and dependig files first.
2012/11/19
I'm a little bit confused..
You asked for the sources from us to build AOSP/CM with own kernel, but don't know how to build a CustomRom for Rockchip? Is this correct?
2014/03/09
JochenKauz said
I'm a little bit confused..You asked for the sources from us to build AOSP/CM with own kernel, but don't know how to build a CustomRom for Rockchip? Is this correct?
Right.
And thank you for such a complete answers to my questions. Probably in this forum does not help me.
Think of yourself your first build ..... you had as many questions ...
2014/03/09
Daughter broke the tablet and test more than anything, that my attempts to further development and porting aosp terminated.
http://4pda.ru/forum/index.php?s=&showtopic=417419&view=findpost&p=30508519
Link to a fully assembled system.img aosp 4.4.2_r2. http://4pda.ru/forum/dl/post/4391980/system.zip
Link to source corrected me. http://4pda.ru/forum/dl/post/4391950/rk29_m971g.zip
73 Guest(s)
Devices in use: Desktop (64), Phone (8), Tablet (1)
lilila3
Anatrop
antoniors021
wemiy54158
sidor
houssmen
