[ROM Request] Android marshmallow for rk3188
2017/08/15 - 21:19
Ok. I need a dmesg from 0.00000 sec. Pls reboot the tab and do the dmesg again.
valdros
Forum Posts: 16
2017/08/15 - 22:57
There it's done. i turned off my tablet and restarted it and just after i redo the log :
https://1fichier.com/?m9s7rzqrb0
2017/08/16 - 19:08
Is wifi on? I cannot see the footprint of the wifi chip.
valdros
Forum Posts: 16
2017/08/16 - 22:09
Hello,no,the wifi was well off i checked
valdros
Forum Posts: 16
2017/08/16 - 22:17
I turn off my tablet then turn it on and activate the wifi and restart the log dmesg by syslog?
2017/08/17 - 21:11
Yes.
valdros
Forum Posts: 16
2017/08/18 - 17:18
Yes.
There it's done, I rebooted my tablet and activated the wifi and just after I did the dmesg log. The wifi is functional, but the wifi chip is of poor quality I think, or the ram is badly managed because all the websites or apps connected to the internet as facebook app or google maps load very very slowly on this tablet. By cons, on my pc the wifi works perfectly well. The problem comes well from the tablet ...
dmesg log:
https://1fichier.com/?gmj8q4aqoy
2017/08/19 - 18:47
<4>[ 136.072322] Current WiFi chip is MT5931.
Build: http://crewrktablets.arctablet.com/?p=5668
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=3155
Temp model fix: http://crewrktablets.arctablet.com/?wpfb_dl=1598
Download build v1.1 and change clust kernel in folder rockdev/Image. Flash according to instructions and install temp model fix in CWM.
valdros
Forum Posts: 16
2017/08/19 - 20:24
Great! I am super happy Smile cyanogenmod 12.1 in 5.1.1 the top! Thank you very much Oma7144 for all your research! I can install it from my 4.2.2? No need to install first a 4.4.2 ?
2017/08/20 - 08:42
Yes. The way is via Flashtool.
looney5508
2017/09/05 - 15:17
Hello, I have a RX5QC.  http://www.ntech.pt/...sheet_rx5qc.pdf
I want to flash it with the (PIPO M1 Pro) firmware but I'm now tottaly sure if it is compatible with mine, can someone here please help me to conferm this or help me to find the right rom to flash with??
here is some other info that might help about my tab;
Kernel ver. 30.36+
root-alex-system-product-name #127
Build# rk30sdk-eng. 4.2.2 JDQ39
eng.root.20131119.153444 test-keys
Hope this helps.., Thanks for any replies..
190 Guest(s)
Devices in use: Desktop (174), Phone (15), Tablet (1)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
