2016/04/10
Will android marshmallow ever arrive on the rk3188 CPU because it would be great if it could.
Unfortunately not. Kernel architecture has changed fundamental and also selinux has been introduced. No one will do the effort to backport all this stuff.
Answers Post
2017/07/25
Unfortunately not. Kernel architecture has changed fundamental and also selinux has been introduced. No one will do the effort to backport all this stuff.- Oma -
What is the most recent rom custom that can be installed on rk3188 cpu for tablet in 2048 x 1536 kernel original 3.0.36+ 9.7 inch please?
LP. Which tab is it?
2017/07/25
LP. Which tab is it?- Oma -
Hello
My tablet is : Clust MPX4C97
The soc is : Rockchip 3188
The resolution is to : 2048 x 1536p
(Active memory-random acces memory) : 2 Go
Core architecture: 4x ARM Cortex-A9 has 1608 MHZ and 32 -bits ARMv7
Supplier GPU : ARM
GPU Renderer : Mali-400 MP
-I succeeded the root with kingo root and i installed busybox pro
-I succeeded to install CWM recovery : "ROCKCHIP GENERIC (RK3066, RK3188) CWM RECOVERY v. Xxxx by fun" installed by Arctools apk in latest version.
Thank you in advance for your answer 🙂
Pls upload the dump and also a dmesg log from a fresh boot. I will have a look.
2017/07/25
Pls upload the dump and also a dmesg log from a fresh boot. I will have a look.- Oma -
All right, but my dump is 2.35GB in size, and I do not know how to send such a large file.
Could you tell me which server, which site to use to send it?
Because I do not know anything in upload.Thank you in advance 🙂
Do not touch the CWM backup. Make a copy first. Then delete data from the copy. Now it should be much smaller.
Upload the copy to a filehoster and post the link here.
2017/07/25
Do not touch the CWM backup. Make a copy first. Then delete data from the copy. Now it should be much smaller.Upload the copy to a filehoster and post the link here.
Hello Oma,I tried to upload my dump by 1fichier or other websites similar but impossible 🙁 I have a debit only to 3mb/ s in download and 0.400 mb/ s in upload and it sends too too slowly, it would take me 1 month and again 🙁
-Here is a screenshot of all my dump files by having removed the data files too big.I can send you with my slow connection just my files of less than 40000 ko approximately, for those of more than 300000ko it would take me several days I think with only 0,400 mb/s of upload 🙁
Ok, then pls upload boot.img and kernel.img. Also do a dmesg log.
2017/07/25
Ok, then pls upload boot.img and kernel.img. Also do a dmesg log.- Oma -
Okay 🙂 It worked, I hope that 1fichier will not erase my links because they have indicated to me to delete the links after a few minutes and that i must save the links....
https://1fichier.com/?7zzexighj4
No. Do it with SysLog (see Playstore).
2017/07/25
No. Do it with SysLog (see Playstore).- Oma -
Thanks 🙂 i installed syslog, here are all the log files of it :
https://1fichier.com/?4k566627nw
https://1fichier.com/?2f9o2rvv9s
82 Guest(s)
Devices in use: Desktop (74), Phone (8)
hans41
rickybk
soniya07
ironmangitar
