2015/02/22
How to install CWM or TWRP on (Beelink R89 Rk3288 Rooted) without computer
Dear Sir can any out there please help me Thank you very much will deeply appreciate Love you
Please show me step by step using ( other apps or ROM ToolBox Lite ) to install CWM or TWRP on (Beelink R89 Rk3288) without computer something like just download apk to R89 TV box and then install directly to the Beelink R89 Rk3288 Devices
Because my computer win xp is very old about 14 year old only have 480MB Ram and unable to recognized the R89 tv box.
Because this is my first time using android devices.If you got the YouTube Tutorial link please let give the link Thank you.
Here is some question hope to get some answer
During update for 4.4.2 to 4.4.4 should i delete
(1)(wipe data/factory reset)
(2)(wipe cache partition)
(3)(wipe Dalvik cache)
2015/06/07
OK, So first you must download this http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rk3288-rom-twrpcwm-flash-tool-custom-root-firmware-20150117/
Next, you must have root. If you don't have root then follow the flashing instructions on the site above.
Now, download something like zarchiver from play store to open the above file. Open zarchiver from all apps and use it as you would a file manager to navigate to wherever the file above is located (probably /sdcard/download/%file%). Click the archive which you just downloaded from within zarchiver and select 'extract to ./<archive-name>/'
That will create a sub folder where you are currently working, named after the archive.
Now go in play store and download JRummy Rom Installer.
After it installs, open it. Be sure to allow root.
Click the three dot menu and select 'Flash Image'. Make sure that recovery is selected and then select image to flash. Here navigate to the folder where you unpacked the archive > inside that folder > rockdev > image > select the screen resolution u want (normally 1920x1280 for R89).
After selecting the IMG you want, read over the flash script, if it looks good press flash, confirm install, and you should be in business!
Cheers!
-SB
Currently Online: Micco, klaus1255
75 Guest(s)
Devices in use: Desktop (64), Phone (12), Tablet (1)
klaus1255
neverever007
favorit
Альфвоф
kevbez
xxxdddd
