I have this one: PCB V8_MV1.1_20130325 - S/N V88 Quad16G2130400xxx
So, same board. Does your S/N contain G2 or G1?
Does the tab have Bluetooth?
In the early times there was a V88 non Bluetooth. This could be a tab with RTL8188.
Build is here: http://www.nathandickman.com/flashing-firmware-chuwi-v88/
stalker021976_1 said
firmware 4.4.2 kernel version 3.0.36+ # 106 .OMA RK31 KKv3.0
If you are on a v3.x build make sure you change the loader first (see instructions in that firmware pack) otherwise you will brick the tab.
stalker021976_1Per aspera ad astra, we rock the Tablets !
Let me have a dmesg log.
Glad to hear that! Where are you from?
If you'd like you can check out this build: http://crewrktablets.arctablet.com/?p=3555
Here is the Chuwi V88 non BT kernel (change in folder rockdev/Images): http://crewrktablets.arctablet.com/?wpfb_dl=707
Install this fix after first boot into CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2013
Hm, check out htis build: http://forum.xda-developers.com/showpost.php?p=47181523&postcount=900
Change kernel in folder rockdev/Images before flash: http://crewrktablets.arctablet.com/?wpfb_dl=707
123 Guest(s)
Devices in use: Desktop (116), Phone (7)
