2014/10/22
Hello! Perhaps you will help my trouble. The bottom line tom.chto have a tablet, originally stood firmware 4.1.1, decided to renew your (4,4,4) all fell perfectly, with one exception - does not work WI FI. after a long search and forum discussions 4pda and tablet showdown, it was found that the module is from realteka rtl8188eus. How we can solve this problem? make friends with a chip firmware rtl8188eus?
Where can I find the stock firmware of your tab?
Try to install attached fix via CWM.
I do not understand.
Which kernel do you use? Where can I find the stock firmware?
This cannot work. Chuwi kernel has MTK 5931 wifi. Your tab maybe RTL 8188.
How is the tab named?
Stock firmware from Chuwi?
There are only 3 Chuwi tabs with RK3188: V17HD, V88, V99x. What size is the tab?
stalker021976_1 said
 V8_MV1.1_2013032
This is a PCB board number. Did you open the tab?
98 Guest(s)
Devices in use: Desktop (79), Phone (17), Tablet (2)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
