You can try combination like:
Volume - and Power Key
Volume + and Power Key
Reset and Power Key
2013/09/28
You can try combination like: Volume - and Power Key Volume + and Power Key Reset and Power Key
Volume - and Power Key: boot normally
Volume + and Power Key: android robot with a red signal as in photo
Power Key Reset and Power Key: the tablet don't power on. The screen remain black.
Can you have another idea?
Well that is the android recovery mode, if you are referring to flashing mode, that is a totally different state of the tablet.
The recovery mode does not work on rockchip tablets (it is not accessible)
2013/09/28
I need to reset my tablet because I have put a password on boot but I have lost it.
In other laptop I have put in recovery mode and I have resolve.
In this rockchip tablet I don't have idea.
You know how to remove the password when they start Android?
If you have usb debugging enabled, yes.
Andrea
Well, you can`t, considering that you need a working tablet, not locked.
There are 2 options now:
1) Dump the current firmware
2) Try to reset the tablet via recovery mode (adb should be enabled by default)
2013/09/28
globula_neagra said
Well, you can`t, considering that you need a working tablet, not locked.There are 2 options now:
If i use adb, when I send the command "adb devices" , the list of devices are empty.
I don't see my device.
If I don't see can how I reset the tablet via recoverry mode?
the lying android with the exclamation mark on it = recovery mode, from there adb should be enabled by default
66 Guest(s)
Devices in use: Desktop (63), Phone (3)
