If you have been following the Arnova tablets story, we mentioned the existence of these devices not so long ago. They are now official on Arnova web site. These are rather basic models: the Arnova 7h G3 is the entry level 7 inches tablet, with 512 Mb RAM, ARM Cortex A8, 1 GHz CPU (probably Boxchip Allwinner A13) coming in a white case. The Arnova 10c G3 has similar specs to the 10b G3: 10.1" screen, ARM Cortex A8 CPU, 1 Gb RAM. Finally the Arnova 10d G3 comes with an 1 Gb RAM, an ARM Cortex A9 @ 1.2 GHz CPU (probably a Rockchip RK3066 running at low clock VIA8850 CPU) and a nice case. Watch soon for a review of these marvels, well maybe
Arnova 7h G3
Arnova 10c G3
manx If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/04/01
Hello,I have an Arnova 10c G3 .I can't use Rockchip Batch Tool 1.5.
I tried everything
-reset+power ( like 9G3)
-volume + and power ,
-volume+and reset (like 10b G3)
-volume and usb cable to the computer (like 8c G3)
Nothing OK .
Someone knows how to root this one?
Thank you for your help
Le Jocassien (a poor french lost with his Arnova 10c G3
I tried everything
Nothing OK .Someone knows how to root this one?
Can you post in text or attach a screenshot copy of the Settings / About tablet screen, I'm quite interested in what Kernel version and Build number lines say.
Thank you.
2012/04/01
For admin
Model nunber;Â Â Â AN10CG3
Android version ; Â 4.0.3
Kernel version;Â Â Â 3.0.8
Buil number;Â Â Â Â Â Â Â Â AN10CG3-eng 4.0.3 IML74K 20121009
                               test-keys
UUID ;Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 2012070400000287
For exelletor
Thank you for you're help,but I have some problem with ADB set up on my computer,i tell you the results of my test.
I was hoping to see some traces of Rockchip (RKsomething) in the Build info, but there is none.
Can you download and install "System Information Viewer" from Appslib, the run the application, go to Hardware Information / CPU Information.
What do you have on the Hardware: Line ?
2012/04/01
Thank for all Admin
CPU Information
Processor:ARMv Processor rev 2 (v7l)
BogoMIPS:1001.88
Featues:swp half thumb fastmult vfp edsp neon vfpv3
CPU implementer : 0x41
CPU architecture:7
CPU variant:0x3
CPU part:0xc08
CPU revision:2
Hardware:sun4i
Revision:0000
Serial:05409429484948488075784916236747
Globula is right, it's very likely to be an Allwinner CPU based machine, some tablets based on this architecture come pre-rooted by default, so I should easily to make an ArcTools package to install Google Play Store like I did for the Arnova 7 G3.
Still I'll need to make sure it works fine and doesn't crash the tablet, as it could be quite a pain to restore the tablet in a working state if you aren't used to ADB and firmware cooking.
I'll try to do that as soon as I get access to an Arnova 10c G3 tablet or someone who is brave enough want to try itÂ
2012/04/01
Dear Exelletor,thank
I had root my device with unlockroot (need ADB). After I installed superuser and busybox,now it's OK.
I want too try install a room (the last for 10b G3)
How can I install image files without Rockchip Batch Tool.
Sorry for my english.
Le Jocassien (a poor french lost without room for his Arnova 10c G3
You can't install an Arnova 10b G3 firmware on the 10c G3, they run on different architectures (10bG3 is Rockchip RK2918, 10cG3 apparently Allwinner A10) they have different hardware/drivers.
2013/01/10
If you search for a 100% working method to root the 10C G3, just use linux and follow this instruction:
Rooted Arnova 10C G3
2012/04/01
yes I know, I would not have do that
I have a big problem,i have installed a room on my devise (10-201220913-unofficial-907 cyanogène)
but now,the tactile screen doesn't function more. Ican use mouse and keyboard ( usb host).
the other problem, the sd card is not recognized anymore, I tried with several,
when I want to download I have the message "your sd card must be install" and I have not access
to the file on the sd card.
how installs a new room to repair the problems.
Le Jocassien (a very very poor french lost with problem on Arnova 10c G3
76 Guest(s)
Devices in use: Desktop (70), Phone (5), Tablet (1)
StatusQ
helloyuen
melcis
nelcis
sophiajohnson87
Brainticket
