[TUTO] Building CyanogenMod 10.1 based [Android 4.2.1] From source for all rk2918
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2013/02/18 - 18:44
Hi Morka,
You have a news about 10 G2?
Thanks!
davis15
2013/02/18 - 18:55
Morka said
@davis15
system.img, userdata.img is file for emulator .
your file is cm-10.1-2013xxxx-UNOFFICIAL-rk29board.zip copy in sdcard with recovery use update on SDcard
I have installed, no error but when dont start i have black screen
JDfense
2013/03/17 - 23:02
Hi Morka,
needed some time to come back, but now I have tested your rk2918 for all.
I have tested it on my easypix easypad 970(clone of cube 9gt2).
I tried it in different combination,
only with the jellybean kernel for my pad from moage.com
with two different recovery for my pad I got into recovery menu,
your boot.img does not work too for me
last choice I use only the system.img from you
then I got the best result a loop but behind the boot.img.
I had no choice to boot it complete.
I have made two logcat files from the loop. One complete, one with only the error. Seems that the hardware is different in some points. Hopefully it helps.
Is it possible, you mean with all rk2918 only all arnova type rk2918?
In my next step, I want to use your tutorial for compiling a rom - big step - after modding some roms, but does your tutorial fit for my tablet?
JDfense
Hannspad with supercharged DRH ICS mod by JDfense ///
Easypad 970 with Oma7144/moage JellyBean mod by stevemp and JDfense ///
Genesis with JDfense's or Stevemp Darwin Froyo ///
Galaxy Ace 2 with stock JB rooted/360launcher pro///
new: Novo Crystal with Crystal JBX by JDfense
68 Guest(s)
Devices in use: Desktop (61), Phone (7)
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
lesfurets
