SD Card Issues
lohtse
Forum Posts: 157
2012/03/20 - 09:14
Sd card issue
Right heres a fun problem for you(fecking annoying for me)..
Have sowa's rom V5rc1 flashed at mo.Great rom but there's a mojor issue regarding real sdcards...
The rom write protects them so nothing can be copied,deleted or moved from it...
So any app that requires ability to download to card(browser or mapping)or saved data cannot do so, nor can I create back ups using Titanium or any other app. it either fails or gives you a warning the saying check you card is write enabled!Now this has happened with 4 cards(16,8,4gig) so far and not sure how to resolve the issue and need it sorting out..
If I eject the card I can download as normal, create backups etc and whilst this is a work around it is pointless for mapping apps and games/apps that download/create data etc on the sd card as soon as I mount the sd card it's no longer usable and indeed can't even find it...
Has anyone had this issue is so how the heck did you resolve it?
Should point out that cards work fine in our other tabs and with PC,Netbook and Laptop. also if tablet connected to pc I can transfer and delete data etc on the sd card....
lohtse
Forum Posts: 157
2012/03/20 - 12:26
So no one has ever had this issue!!!!????   Hmmmm whats the damn point off having an sd slot if you can't use the damn thing!!!??
Currently Online: -wall-, JSun
97 Guest(s)
Devices in use: Desktop (89), Phone (9), Tablet (1)
kuzdeen
el jonky
maxmintus
cngulhane
cipek123
zerpur
Topics: 6010
Members: 260665
