[MorkaMod][Android 4.2.2 full ASOP][All RK2918]
Monach
2013/03/05 - 18:31
Hi Mark, I have arnova 7 G2 but I can not put this firmware on it because it shows the logo on a black screen and vse.a already tried recovery.img MorkaMod V1.3 Fix to use the exact same situation. Sorry for my English.
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2013/03/05 - 19:27
Now I have my new tablet, I would wear a functional version
Version 2 does not start also for those who wish to test
MorkaMod-V2B2.zip (293.8 MB)
https://mega.co.nz/#!QNtXiZQJ!B0G-xmj7KRLf0Pu6Jpj9gDfOhDNrUMBH_-JzvSpTgt8
Sowa
Russia, Novorossiysk
Forum Posts: 47
Thanks Received: 5
2013/03/05 - 19:33
Tip to the mega:
"The file you are trying to download is no longer available."
China phone: Star A5000 => Star N8000
Tablets: Archos 7C HT - Android 2.2.1 my custom ROM => ARNOVA 8G2 8Gb capactive, s_MorkaMod JB 1.2
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2013/03/05 - 19:38
Tip to the mega:
HI Sowa
Sorry I'll upload it arctablet
Sowa
Forum Posts: 47
Thanks Received: 5
2013/03/05 - 19:45
Morka said
HI Sowa
Hi! Morka. Good for you (New tablet)
Most likely not a valid link, try to correct the.
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2013/03/05 - 19:59
Sowa said
Morka said
HI Sowa
Try this link
Key : B0G-xmj7KRLf0Pu6Jpj9gDfOhDNrUMBH_-JzvSpTgt8
Compatible firefox link
Sowa
Forum Posts: 47
Thanks Received: 5
2013/03/05 - 20:04
Sowa said
Morka said
HI Sowa
Answer: Enter decryption key :) File is public ?
P.S.
Introduced a part of your links and file downloaded !
Remove your key
PPS
Kernel for what model?
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2013/03/05 - 20:13
kernel 8G2i Base in morkamod 1.3
Sowa
Forum Posts: 47
Thanks Received: 5
2013/03/05 - 20:18
Excellent!
We'll see. As always, this will change. :)
eagles
2013/03/27 - 08:40
Hi Morka,
search google to find your release flash
 I have an unknown brand tablet.  Kernel 2.6.32.27 / M2907 Build / Android 2.3.1 GINGERBREAD / Hardware RK29board / Processor ARMa8 Processor rev 2 (v7l) /Screen  Resolution: 800 x 480
Do you suggest me to test your creations for my device?
hlodolo
Arras
2013/04/03 - 23:30
Hi Morka (Chti power)
I have tested yesterday "CrewRKTablets_RK29_Loox_AOSP_4.2.2_20130222" and replace kernel by "kernel_308_10bg3_arnova", not the dt one (but i think my tablet is a dt but whith this kernel it doesn't start)
install fix :
"CrewRKTablets_AOSP_4.2.2_120_DPI_Fix",
"CrewRKTablets_AOSP_4.2.2_Format_NAND_Fix",
and try without "CrewRKTablets_AOSP_4.2.2_Sensor_90_Degree_Fix". the screen can only be hold verticaly.
and i install "CrewRKTablets_AOSP_4.2.2_Sensor_90_Degree_Fix", but the rotation work upside down, it is no usefull. I don't know if it can be invert.
But it seem to be imposiible to move app to SD.
I tried to do it with the fix of oma (extsd to nand, i have tried either ext to nand otg) but it doesn't work) I will try again later.
This firmware do not have problems with sound, and it is rooted. If you can solv your problems of sound, of ext sd space and the root without sensor bug, it would be nice. For me i wait for root for reinstall my apps.
peterico
2013/04/25 - 19:09
Morka
Do work-HW-Decoding of media contents,camera and micro?
I put the version of OMA and does not work
ac78912
2013/04/27 - 03:10
jb v1.3 also cant be extracted mainly the system.img. whenever I tried, it said system.img is corrupted.now what to do??????
dammy
2013/06/12 - 11:11
Can you tell me if this rom is compatible with the Arnova 10b G2 capacitive?
Thank you for your work
Dammy
Opus
2013/06/14 - 15:42
i cannot get this to work on my 8 g2 .
It uploads wel and after the rkandroidtool 1.29 says info run ok the tables reboots but hangs on the ARNOVA screen and from there it does nothing.
Is there anything im doing wrong ??
Oh and i used MorkaMod-V2B2 :( tablet doesnt do anything anymore now
87 Guest(s)
2 Guest(s)
Devices in use: Desktop (71), Phone (14), Tablet (2)
jessicapeterson
Riki111
andre92
firmwarefile
mongol
country822
