2012/11/22
I've installed MorkaMod with Jelly Bean v1.3 on my Arnova 8 G2, even I've modified build.prop with this lines:
# Set operator numeric Market Fix
gsm.sim.operator.numeric=310260
gsm.operator.numeric=310260
gsm.sim.operator.iso-country=us
gsm.operator.iso-country=us
gsm.sim.operator.alpha=T-Mobile
gsm.operator.alpha=T-Mobile
I can't install most of the apps in the Market it says: 'Your device is not compatible with this version'... no idea how to solve it... can you help me?
I've also tried to change density and an app called 'Fix Market'... but still the same...
2012/09/27
# Set operator numeric Market Fix gsm.sim.operator.numeric=310260 gsm.operator.numeric=310260 gsm.sim.operator.iso-country=us gsm.operator.iso-country=us gsm.sim.operator.alpha=T-Mobile gsm.operator.alpha=T-Mobile  I can't install most of the apps in the Market it says: 'Your device is not compatible with this version'... no idea how to solve it... can you help me? I've also tried to change density and an app called 'Fix Market'... but still the same...
Use Market Helper, link:Â http://codekiem.com/2013/02/13/market-helper/
Set as Nexus 7, you will see all!!!!
The following users say thank you to lolloarnova for this useful post:
estribiyo
2012/09/27
2013/07/03
Hi @all.
I've got a Arnova 7 G2. I've still installed Omas JB Rom, Crewrktablet Rom and MorkaMod Rom. MorkaMod has got the best performance but many things don't work. I've tryed all the Fixes, but still same problems (missing main keys, wrong resolution etc.).
Has anybody a update.img, which solve the problems and which is tested on 7 G2? Or some other hints?
Tanks a lot
dom_t64
2013/01/27
installed on my Arnova 8g2Â Android 4.1.1 Jelly Bean and it looks great !Â
My unsolved problem is the connection between the 8g2 and my Nokia 5800 with an adhoc connection.
tryed to find a solution with programs but it seems to difficult for me.
can you explain to me how to solve this problem?
someone could help me ?Â
thanks
2013/01/27
found solution on this forum changing the wpa_supplicant with the file unzipped
http://acer-a500.ru//uploads/files/1313343315_wpa_supplicant_xoom_wifi_adhoc.zip
renaming in sistem/bin/wpa_supplicant to wpa_supplicant_old (in case of problem
my problem is that normal home connection is lost by my 8g2 when stand-by
only turn wi-fi off wait and turn-on the hone connection became available.
No problem with AdHoc connection with my Nokia 5800
maybe someone has a filw wpa_supplicant that works better on our tablet?
ciaoÂ
2012/02/06
I have just install the MorkaMod with Jelly Bean v1.3 in my 8G2 DUAL TOUCH and the install was perfect!!
But only works with a mouse!!!jajaja, but perfect with the mouse in a mini usb adapter.
Dont work with the fingers??
 thansk a lot.
WARNING: NOT WORK IN 8G2 DUAL TOUCH ONLY WITH MOUSE AND CANT CONNECT WITH THE PC .
2013/11/09
What "..EraseIDB, tick Loader, Run" means?
also "For 8G2 ,8G2i 4Go and 8Go copy kernel.img file ,folder /rockdev/Image"Â
does that mean to paste the kernel.img in folder /rockdev/Image and save the MorkaMod JB V1.3 zip file modified?
Another problem I have above all is to install the right driver for Rockchip_Batch_Tool to recognize my tablet, I tried on 2 different PCs and they both keep installing the drivers by default even if i set windows to not install the drivers.Â
Please help!
thanks
Currently Online: iposad40
74 Guest(s)
Devices in use: Desktop (66), Phone (9)
mongol
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
