2012/12/12
So i went back to morka 1.2 final now and the google play store works again with all apps.
After i go back to 1.3 final nothing on play store works.
So its def a problem in the 1.3 final that does is not compatible but i dont know what.
For now i will stay on morka 1.2 final.
Hope Morka can give an answer or fix soon.
Happy New Year everyone
The following users say thank you to Opus for this useful post:
Morka
2012/01/06
@schnappi59, @Opus
First I Thank You for error reporting
USB Host error with the file vold.fstab
fix
Line to modify
dev_mount udisk /mnt/usb_storage auto /devices/platform/usb20_otg/usb1
With
dev_mount udisk /mnt/usb_storage auto /devices/platform/usb20_host/usb /devices/platform/usb20_otg/usb1
For google play store
An error caused by me ,code written in the file init.rc
# Set operator numeric Market Fix
   setprop gsm.sim.operator.numeric 31026
   setprop gsm.sim.operator.alpha T-Mobile
   setprop gsm.sim.operator.iso-country us
   setprop gsm.operator.numeric 31026
   setprop gsm.operator.alpha "T-Mobile"
fix
edit the file build.prop add to end of line
    gsm.sim.operator.numeric=310260
     gsm.operator.numeric=310260
     gsm.sim.operator.iso-country=us
     gsm.operator.iso-country=us
     gsm.sim.operator.alpha=T-Mobile
     gsm.operator.alpha=T-Mobile
After modified build.prop
Step 1:
Go into Settings - Applications - Manage Applications - Market - Clear CACHE - Force Stop
Step 2:
Press back once - Google Services Framework - Clear DATA - Force Stop
Step 3:
Reboot your device
Step 4:
Open the market again and enjoy. You now have a fuller Android Market.
2012/03/25
I just installed your 1.3 rom on my Arnova 7G2. I followed all the steps, copied the folders but I noticed that there are no buttons on screen (return, home,...). I also noticed that the clock in the top right is cut in half. Did I do something wrong?
I've also noticed that my notification bar is on the top but in your screenshots it's located at the bottom.
2012/01/06
Hello Vrailink
ukbeast said
I am on arnova 7g2 and I've got weird screen resolutions.90dpi seems best
I did not test this model, but the user did ukbeast test
edit the file build.prop line
ro.sf.lcd_density=120
With
ro.sf.lcd_density=90
Vrailink
2012/03/25
still nothing..
Other problems I've encountered:
-the sd-card isn't recognized by any app. They all say "no sd-card found". When I go press on sdcard in root explorer is says "no sd-card mounted"
-Connecting my tablet to a pc does nothing. Even when I disable the usb developer thing I still can't enter the tablet from my pc. Maybe it has something to do with the problem above?
2012/11/11
Vrailink said
still nothing..Other problems I've encountered:
Exactly same 3 issues on 7fG3. Need Time to investigate more...
Cheers,
Glob.
Globulus2906
3 Arnova 7f G3 (1 with screen broken)
+ a couple of other Acer and Samsung's devices....
2012/03/25
Ok I tried to look a bit into it and discovered that we can access the storage but the system doesn't see it as mounted.
What I mean by that is that I can acces the folder /storage/sdcard0 and I have all the folders and files that are stored on the internal memory.
But when I click on /mnt/sdcard it says sd-card not mounted.
When I change the name of the folder then it opens just like that but the apps still can't access it.
I hope this helps
I also can't get all the apps in the market even though I edited build.prop and followed the steps. I tried to search for sonic (from your screenshot) and dropbox. none of them appeared..
It seems all of the above is working in version 1.2 (except for the bottom bar problem)
2013/01/01
Hi Morka......
Installed on a Arnova 9G2 - problems with Camera .....I´ve removed the Icon from home Screen because after starting of the camera app i´ve got the error message "No Memory" (German: Kein Speicher) No external Memory available (Kein externer Speicher verfügbar)
"Stellen sie vor Verwendung der Kamera einen USB-Speicher bereit"Â
So i removed the Camera icon from the Homescreen ----- but the camera icon also dissapeared from the app menue all apps
Second Problem is that i can´t view pictures from the inserted SD card - if i open the galerie i can see folders in the background and i get an error message No Memory - No external Memory available
Any ideas how to fix this?
Currently Online: Bart68000
85 Guest(s)
Devices in use: Desktop (68), Phone (17), Tablet (1)
jessicapeterson
Riki111
andre92
firmwarefile
mongol
country822
